C1223/C1256 abs codes on scanner but no engine codes or lights
keakar
I have 2 codes that show up on my ob2 scanner (06 4runner 4.7 v8 sport)
1 - C1223 malfunction in antilock control system
2 - C1256 accumulator low pressure malfunction
so what is going on and what do I need to buy (or do) to fix this?
I should ad that the brake fluid looks clean and is at the full level mark
also if something is wrong with something, why didn't I see a check engine code?
Hey guys - just giving this thread life again. I’m in the same situation and have a 3 codes with no CEL illuminated: (03 v6 4wd 230k)
C1223
C1256
P0430 bank 2 (this one in scanner is labeled “history”?? I replaced gas cap and the CEL went off last week)
Because the CEL / vsc Trac lights disappeared I stopped by a shop to make sure the p0430 was really gone, but then I got more than I bargained for with the c1223 and c1256. Didn’t even know anything was wrong. Can’t find a whole lot of guidance but welcome any thoughts of how to go about it. The brakes seem to be working just fine.
Any ideas?!?!
