Cabin air filter 1 yr. update
yabedude said:
Just picked up 2 non-carbon versions of the Micronair filter from Canadian Tire in Mississauga, ON. Checking in the local store in BC yesterday revealed they don't carry them, so hopped on a jet this am just to get these ;-)
I have order a MicronAir from Canadian Tire in Kamloops, BC. Should be there by now, a shorter trip?
Not really. A 4 hour flight versus a 4 hour drive. With gas prices the way they are, I probably got a deal flying to Toronto. :bs: :jester:
Thanks for the help. Today I changed my filter by removing one screw. The filter cost $22 at the local parts store. The dealer wanted $32 plus an hour labor. So you guys saved me about $70. I've seen both filters and they look exactly like each other. I'd hate to think what it would cost me at the dealer if they had to really remove 4 screws like the Service Advisor told me. I guess, at the dealer it's one hour per screw, sounds like they are no different than a massage parlor. I think I'm going to look for a dealer that has female Service Advisors.
I live in Los Angeles CA. I went to Autozone.com but i can't seem to be able to find the Bosch filter. Do you have the part #?
" went ahead and ordered the Bosch from the local AutoZone for $19.95. I will let you guys know if it looks better than OEM. Like the MicronAir they talk it up but don't give any spec's. I'll have it Friday."
I bought the one from Bosch at AutoZone, it is better than the OEM and was made by MicronAir for Bosch. You did good. :)
SoCalRunner said:
If anyone can come up with a more secure work around for the 3M cut-outs I will go that route....in about 6months.
simple. Just DUCT tape around the edges (1" in or so) and it'll be fine. The air isn't going to start curving around things and finding the longest route through.. it'll just go straight through the filter.
I think air is probably like water and will flow through the path of least resistance, i.e. leaks.
I'm in the market for a new in-cabin air filter and read bulldog's post on another forum about the Bosch/Micronair filters. My local autozone had no idea what I was talking about and told me it didn't exist, so I've been looking around online for one tonight, and think I found that you can order them from autobarn.com here:
http://www.autobarn.net/boschcabinairfilters.html
http://www.autobarn.net/particulatefilter.html
Hopefully one of you guys can chime in and let us know for sure if that's the one or not.
I can't wait to pull mine out and see how it looks after all the dust and dirt and mud I've been through ... I haven't changed it since I bought it ummm ... a long time ago. ;)
I can't wait to pull mine out and see how it looks after all the dust and dirt and mud I've been through ... I haven't changed it since I bought it ummm ... a long time ago. ;) [/B]
You will be in for a surprise then because yours will be completely clogged and dark gray in color. It is best to replace it at least once a year. I try to remove mine every six months and reverse flow it with my air compressor. I have also washed mine in soap & water between changes.
Yes, that is why I look forward to seeing it. I did actually take it out at some point last year, but it looked relatively clean so I put it back in. At the time, it was the least of my concerns.
Maybe I'll post a pic when I pull it out.
thanks for the advice!
BOSCH P3785 PARTICULATE FILTER
Note: glove box 21.95
That's the one, but it sure seems pricy.
Up here in the Great White North, I bought a 1/2 dozen Micronair cabin filters (part# TY00145P) for something like CAD$17 each (at the time). Canadian Tire part # 23-3836-0. Only found them in Mississauga though, not in the Greater Vancouver area.
The mfgr web site(s):
http://www.micronair.com/ (doesn't list that part)
http://www.micronair.us/Toyota/99 ($24.16 That's also expensive!)
Yours must be in bad shape considering you've been off-roading in the dust.
That isn't the charcoal activated one though right?
If it is just a particulate filter then that is the same as the OEM one and you can get those for around $17.
I can't seem to find the charcoal activated ones so they may not make that one for the 4runner yet.
I haven't seen charcoal ones either.
