Can I make my power socket constant?
so the wire replaces the relay?
:confused: Not sure what you mean by 'replaces?' The relay is still there, you just run a wire to "jump" two different parts of the relay. Probably be more accurate to say the wire allows you to bypass the relay, because the relay itself is still there.
I've done the ac mod. What about the one by the shifter
I did this mod a few months ago and what I discovered was that this mod will put the front and rear 12v power outlets into full-time-on mode.
However, if your 4runner has a cigarette lighter (and mine does) in the console, that's on a separate circuit so it will only be on when the ignition is on.
I suppose you could do that, I did this and the full time window mod and removed the relay on both mods. I have also done the fog light mod and that one retains the relay as you bend one pin and jumper from there.
AndiGarage
