Can I run 33x12.50 Tires with 3/2 spacer lift
2005v8sport
Excuse me if this is a newbie question. But will a 33x12.50 tire fit on the stock 17" sport wheel with a cornfed spacer lift and spidertrax spacers? It seems like everyone always runs a narrower tire on the 4th gens than at 12.50 and I was wondering why? Any help would be greatly appreciated. Thanks!
Uhh I'm sort of a newb and don't know what 33x12.50 means but I have a similar question.
Is 265/75/17 the appropriate size tire with a 3/2 lift and no spidertraxx?
I'm not sure, but I think 12.5" width is on the large side. What your wanting to do is a bit more than an inch wider than what some people already do on this tire, so IDK.
285/70/R17 33x12.50/R17
32.71 (830.8) 33.03 (838.84)
11.22 (285) 12.52 (318)
No. You have to have more lift than that. A 285/75 will rub without a 1" body lift OVER that 3/2 and some cutting. The 12.5" is also wider than the 285/75 so you'll have even more problem. You can do a 265/75 with most tires and no rub, probably a 275/75.
You will need major trimming to fit that size with your spacer lift and even with the trimming you will rub at full locks.
Also consider a 1.5" body lift would help.
I just recently threw on a OME hd 3" lift. I've got some black rock d-window 16x8 w/ 4.25bs on order. In the mean time I picked up a variety pack of 305/70/R16 mud terrains (5 for like a hundred bucks used) anybody think they'll fit
