Can I tow my car with the runner?
stoker8
I have a 2004 V8 4x4 4-runner SE
I'm wondering if I can tow my 3500lb Supra with it. The Supra and trailer will weigh about 4500lbs. I plan on towing it from Houston TX to Orlando FL.
A friend that works at the toyota dealer said no, that the car and trailer weigh more than the 4-runner. But, isn't the 4-runner rated for 7000lbs?
Thanks.
Are there brakes on the Trailer?
I have a 05 Limited V8 and I tow a boat and trailer that is around 5300 LBS with no problems at all. The trailer has Surge Brakes though. If I had no trailer brakes, it might be a stretch.
Cheers,
No problem
The 4runner can tow it no problem, but your trailer should definitely have it's own brakes. Otherwise a load that heavy will control YOU when braking. I would use trailer brakes when towing a load over 3500 pounds.
Thanks guys.
I don't know if the U-Haul auto carrier has brakes. Pretty sure it doesn't. Are there rentals that have brakes?
Not sure in those states but in Ohio, it's the law that any trailer with a groos over 2,000# had to have brakes, either electric or surge. I would think a U-haul trailer that is capable of carrying that weight would have the brakes to comply with state laws.
here you go -
Auto Transport
The most secure way to tow your vehicle. U-Haul is the only national company that rents towing equipment without a truck rental.
More on U-Haul vehicle trailers Reserve now
Capacity
Max load: 4,000 lbs.
Gross vehicle weight: 6,000 lbs. max
Empty weight: 2,000 lbs.
Features
Easy-access loading ramp
Tilt-out fender allows vehicle door access
Ratchet-operated tire straps
Vehicle security chains
Automatic hydraulic surge brake http://www.uhaul.com/guide/?equipment=autotransport
btw - I would make sure the vehicle you are towing does not need extra insurance if you are towing as opposed to driving it...
Great info.
So I gather that if the trailer has brakes I'm ok.
Thanks again.
And thanks for the insurance heads-up Dave.
