My A/C light blinks and doesn't work. I looked up the symptom and lots of posts point to a relay under the hood. I've checked it out and swapped the Fog light relay and A/C relay and both seam to function fine.
I haven't used the a/c since my timing belt change in Dec. I suspect it might have to do with the timing belt change and the mechanic. I poked around under the hood and noticed that there is a bracket and wire that are not attached coming off the a/c compressor. The bracket itself is loose and can be lifted off by hand, there is also a black ground wire that isn't connected either. I want to attach the bracket and wire to something but I don't see a mounting hole on the compressor to bolt it down
Have a look at the pic and if someone can show me what theirs looks likes or guide me....that would be great.
