Your breather vent may be clogged causing your seal problem.
I don't think it's grease you're seeing but gear oil.
What makes you think it's grease?
Have you checked the fluid level in your rear differential?
Is there a way of replacing the grease that washed out of the bearings?
Sealed bearings, so they aren't designed to be repacked. You could Try removing the plastic side, though the ABS ring would make it next to impossible, and do your best to pack some grease in there, but it'd be a short-term fix if it fixed anything at all. Absolutely no way to access the other side of the seal without pressing everything apart, at which point you're 99% of the way to just replacing the thing.
Have you watched Timmy doing this job to see what's going on? My guess is that the seal retainer (piece that the seal rungs against) wasn't flipped to compensate for the redesigned Toyota OEM seal.
YouTube
Even if you're not going to do the work yourself, it's helpful to know so you can point out issues to a mechanic (who doesn't know every detail of every job) any potential issues so you don't end up back in the same place again a year later.
The seal is in your axle housing just inboard of the abs sensor. I used a Lisle seal puller to remove mine. It's not necessary to remove the abs sensor for this job.Thanks for the inf, thats what I was hoping. My breather is functional. So guess its time to pull the axels and replace the seals. Bummer.
How or what did you use to pull the seal? and from where? outer(wheel side)?
Currently having difficulty removing the ABS sensors so I can remove the axels? any ideas?
thanks again
Jerry
thanks again
Jerry
I'd order 3. It's pretty likely that you'll mess the first one up.Great info. I thought the ABS sensor had to be removed because it stuck out into the axel tube based on its shape. Good news Im going to order 2 of the new Toyota seals and give this a shot.
Thanks for the help!
cheers
Jerry
