Can you clean the inside of the headlight housing?
Dianna
Member
I have a 2014 and the top of my headlights, on the inside have what looks like algae inside them. I have never noticed any moisture. Is there any way to clean the inside of the housing? I'm tempted to use this as an excuse to buy LED's, but hoping for a cheaper solution!
Blah, thank you for the responses. I guess I will go the upgrade route and wait for my winch bumper. Judging from the lack of responses and when I searched I didn't find anyone else with this issue, it must not be a common problem. Was hoping for a TSB, but it's on top and doesn't really effect the lighting. Thanks again guys :)
My 2016 has what appears to be liquid residue from if you let water run down something and let it dry up without wiping it off. I think it is condensation over time that has done this so while not algae so to speak mine has similar in the housing type issues.
I'm glad it's not just mine, Toyota is good at fixing a mass problem but I don't see them covering this if it's only a handful of us.
Try this.
Remove the housing(s) from the vehicle. Remove the bulb(s).
Put some crushed ice inside the housing. Swirl, swish, shake, agitate the ice. See if that removes the foreign material.
Dump thr ice/water out. Dry. Reassemble.
Sent from my SM-S908U using Tapatalk
Try this.
This is genius. I would add a final rinse with distilled water to discourage water spots as the water dries.
And while you’ve got the housing off the car and full of water, maybe see if you can find how the moisture got in there to begin with by looking for leaks.
Isn't this how they clean coffee pots?
I’ve used a length of ball chain for similar purposes in the past, but I wouldn’t use it with the relatively soft plastic of the headlight housing. I’d consider using plastic beads instead of ice though.
Ball chain:
youngrk
