can't find correct heater core
c west
I have an 89 w/o auxiliary heat I bought a heater core from parts geek a month ago finally got around to changing it out and when I removed the old one I found out I bought the wrong one and I can't find the right one mine needs the one that the brass tubes go into it can somebody help me find one and the retainer clips for the tubes the date on the door frame is 10/88 but title says 89
My heater core is 8 5/8 x 5 3/4 x 1 1/4 can't find one the old tubes fit with the old retainer clips can some body pleas shed some light on where to find the right core
Did you try RockAuto Parts Catalog
VISTA-PRO Part # 399321 {#9321} One of our most popular parts
TO 3/89; W/AUXILIARY HEATER, FRONT UNIT (Only 2 Remaining)
Part Image
$37.79
PRO Part # 9010006 {#8710789112} One of our most popular parts
Front
Part Image
$76.79
SPECTRA PREMIUM / COOLING DEPOT Part # 94791 {#94179} Core Dimensions: 8 5/8 x 6 1/2 x 1 1/4; Inlet Pipe Diam: 5/8; Outlet Pipe Diam: 5/8; Material: Brass
Part Image
$81.79
VISTA-PRO Part # 394179
FRONT UNIT, W/O AUXILIARY HEATER
Part Image
$83.79
None of those match mine perfectly the closest one was one inch short can't tell if the flanges will match will one that is that close to the same work? It is hard for me to tell if I can't see it and compare to what I have
So I have tried three different heater cores this week and none of them were right none would work at all has anyone ever changed a heater core in 89 4 runner dlx no rear heat with ac ?
I have an 89 dlx and 9 times out of 10 you're going to get the wrong part if you ask for an 89. I usually just search for an 88.
