TechOp
Hello gang,
I drive a 93 4runner that wont pass emissions. I have done all the first steps to fix the 25 error code(too lean) by replacing the MAF, O2 sensor, plugs and wires, ignition coil, cleaned cat, replaced injectors with 4 hole, distributor cap, value cover gasket, cleaned intake, clean/checked throttle sensor, reset computer, check egr and replaced water pump(not related). Truck runs rough so i checked the timing. The timing mark is on 0 when cyl 1 is tdc but when i turn the cap way past the mark the idle is smooth with a little backfire when you accelerate. So i thought that maybe the timing belt was off from the water pump replacement so i checked it. I hand turned with a screw driver in the cyl 1 and lined up 0 with tdc. Im stuck!!! The exhaust smells like too much gas and now im getting 2 codes too lean and knock sensor. Could it be the ecu???
