Can't turn key after reconnecting battery
Zvander
Hi every one.
I have an issue and I'm looking for help/answers. I've got a 2003 4Runner LTD. About a week ago I got a CD jammed in the JBL stereo (follow me, I'm going somewhere with this). No matter what I tried I couldn't get the CD out. I read somewhere that you could duisconnect the battery, then reconnect and it should eject. Well... I tried disconnecting and reconnecting the battery, but now I can not get the key to turn! WTF?! I tried it several times (with another key too), but it will not budge!
Has any body had an issue like this and/or know of a fix? I've never heard of the ignition cylinder locking up due to a disconnected battery.
Any help would be greatly appreciated... considering my 4Runner is now a brick.
(...and I thought my issues were over after my EPIC Fail with the master cylinder a while back... that only set me back $3500.00 to have it replaced!)
Hi every one.
Is your steering wheel locked?....
Nope, it's not locked (that was one of the first things I thought of). The key is not moving though, just as if it was locked. I'm stumped. But I know once I realize what the issue is (right after someone throws me the idea ;) ) I'm going to feel soooo stupid.
OK, so I knew this would be the case... After checking the codes I came up with an error code: ID10T. Yup, I'm an idiot.
When I tried moving the wheel and turning the key, I failed to take into consideration I was parked in a snow pile! After trying it again, but this time cranking on the wheel, it turned and started right up.
Well, like they say... you can't fix stupid.
Thanks for the advice.
Jhunt
