Cargo area 12V plug Removal
gaterose
Senior Member
Does anyone know about this?
I've had the panel out before but never had any luck removing the plug to integrate into my sub box that covers the original location.
I've tried a couple of times but can't figure out how to get the plug unlocked or what kind of clips are holding it in.
I did a couple of searches and check the service manual but didn't find anything.
I know I could just buy a new plug but I like that one and it's there so please don't recommend buying a new plug.
I don't believe it screws together. I think it snaps in somehow but I can't tell where the release is or if it's a twist thing.
Wish I had a picture but I won't have time to pull the piece and look at it for a few days.
Guess I'll just bump the thread then.
From the FSM:
Your Vehicle: 2008 Toyota Truck 4 Runner 4WD V8-4.7L (2UZ-FE)
Vehicle » Power and Ground Distribution » Auxiliary Power Outlet » Service and Repair » Rear Power Outlet Socket » Removal
Removal
OTHER SYSTEM: REAR POWER OUTLET SOCKET: REMOVAL
REMOVE REAR DOOR SCUFF PLATE RH See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE REAR DOOR OPENING TRIM WEATHERSTRIP RH
REMOVE BACK DOOR WEATHERSTRIP
REMOVE REAR FLOOR MAT SUPPORT PLATE REAR See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE DECK BOARD SUB-ASSEMBLY See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE DECK BOARD ASSEMBLY See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE DECK FLOOR BOX RH See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE REAR DECK TRIM COVER See: Body and Frame\Interior Moulding / Trim\Headliner\Service and Repair\Removal
REMOVE TONNEAU COVER HOOK A
REMOVE RR POWER POINT SOCKET ASSEMBLY
(a) Turn the socket in the circumference direction as shown in the illustration, disengage the claw between the socket and the RR power point socket cover, and push out the socket to the room side.
(b) Align the socket with the notch on the RR power point socket cover, remove the RR power point socket assembly to the room side.
Awesome, don't suppose you can post that illustration?
edit - nevermind I found it, also forgot to say thanks... :thanks:
