Cartrimhome Flip Key?
Probably a stupid question but would I be correct in assuming that you have to bring the new remote to the dealership to program?
The only information I can find is that you need to use Tech Stream software with a mini VCI cable to program a new key without going to the dealer. I'll most likely attempt doing it this way if I can avoid a trip to the dealership.
I like the idea of a flip fob. But it seems that the plastic piece will stick way out of the ignition and is likely to get in the way and get bumped a lot.
I don't think it would be any different than the OEM key. It's going to stick out regardless. The idea is that if you stick this into your pocket it's not going to stab you or poke a hole through your pocket.
Here’s how I understand the flip fob.
- You’re getting a plastic shell with an uncut key.
- You have to do surgery to gut your OEM key to take out the transmitter/battery/keypad assembly and install it in the new fob.
- You also have to remove the little security chip and install it in the new fob.
- You then have to have the key cut at a locksmith. Don’t use HD or such. Make sure they do a good job. I’ve often had duplicate keys made and some did not work. You only have one shot with this. In fact, you should probably have the key cut first before destroying your old fob.
MESO released their Flip Fob's today. $82 out the door. I ordered one so we will see how it goes. Hoping for a good quality product since its a little more than double the cost of other normal aftermarket fobs.
FlipFob 4-Runner
– MESO CUSTOMS LLC
I’m interested in this but wondering about the strength of the plastic holding the actual key. Whether it’s strong enough to withstand many years and thousands of twists to start the ignition.
Thanks for being one of the first buyers.
Looking forward to your review.
I ordered 2 flip keys from CTH and what I did, I ordered 2G keys from amazon ( Amazon.com: Keyless2Go Keyless Entry Remote Car Key with G Chip for Select 4Runner Rav4 Yaris Models That Use HYQ12BBY, HYQ12BDC (2 Pack): Automotive ). I programed these keys with Techstream, removed the internals (chip and door remote) and moved into the flip keys.
This way I still have the keys that came with the truck and can always go back.
The flip key looks strong enough to work for years but I still have backups if need it.
FlipFob 4-Runner
– MESO CUSTOMS LLC
Like Electro said, excited to see your review. I have a nasty tendency to put my keys in my backpack with my sunglasses so the MESO Fob is on my radar, for the sake of sunglasses =)
Hi, sorry for the late response. I didn't take it to the dealer. I found a local auto locksmith who could program it. I believe cutting the key and program cost $75 for me.
Google auto locksmith in your area then ask if they are able to program.
DJNutshell
