Caster question.
Yoderguy
My SPC arms came in this week and yesterday I installed them. Went to get an alignment and I had a .6 difference from side to side. My LCA bolts are froze so there wasn't much that could be done at the shop because they were very busy at the moment. He dialed in EVERYTHING perfectly but it pulls annoyingly enough to the right due to the caster split.
My question is, can I take the wheels off and move my SPC arm up to the next caster mark on the side that's lower without destroying my camber and toe. Or is it a must to go have it aligned again?
Sent from my LG-H811 using Tapatalk
Unfortunately you will have to align it again. Changing one angle virtually always makes a change to at least one of the other angles. Your toe will definitely be affected.
I kind of figured, part of me just hoped +.5 caster on one side would be doable. I shoulda known better. Thanks for the words man.
Did you find you needed UCA's with the 2.5/2 dobinson lift, looking to get exact same setup and trying to see if you did it because you had to or it was reccomended.
H.Sikina
