DIY Alignment Tools
Whoa there, bump steer is a thing, and camber changes with suspension bump/droop when you have unequal length non parallel a-arms. I would only adjust suspension settings at ride height on an IFS vehicle. You can set toe on a solid axle up in the air though...
-Charlie
Yes, point taken.
I was not recommending Camber be adjusted with the wheels off. I was just saying there are ways to do this, involving some pre and post measurements of ride height vs @ droop. I adjusted my Camber on the ground. I adjusted the Toe with the suspension at droop, including centering the steering wheel. All of that is on spec now. It wasn't when I started.
EDIT: If Toe changed as the suspension cycled on this type of IFS, you'd have some WEIRD tire wear. It doesn't change since that adjustment is controlled by the Outer Tie Rod, not the Alignment Cams. I can't see a change in the Toe when adjusting Camber on this particular vehicle. Mind you, I'm making small changes, but that's my experience.
Yes, point taken.
Camber is pretty well known to vary with travel on most IFS systems. If the camber changes, toe changes with it.
It's what has kept me from doing a full alignment in my driveway. It needs vehicle weight to make all adjustments. Only option would be hub stands. Those are pricy, if they exist for the 4r. Toe is always adjusted last. Toe does move during suspension travel, it's a tiny amount but it does move.
so yes maybe not perfect...but I did ask...will these plates clear a tbu caliper...so i can get near enough to take to a shop to fine tune
There is a different style of toe plate that allows you to leave the wheels on. More of a solid plate with stand-off studs that are adjustable.
Doesn't take much. A 4-foot level along the tire to eyball to the rear axle will get you pretty close. You can roll forward and back after each adjustment to remove pre-load on things instead of using slip plates. This was on my slanted driveway, 100% by eye (before numbers):
Start with "max caster" (lower ball joint full forward) and adjust to get camber in spec, then set toe. I'd be happy to drive on the above 'before' alignment a few hundred miles before getting to a shop to let the suspension settle in.
Here's an FSM page for settings at stock height for reference:
The negative camber happened since I am so used to looking at car alignments with 1-2* of negative camber...
-Charlie
erinobr2000
