CB antenna mount
opie74
Anything think this will work? Its for a 93-98 T100, but looks like it will line up with the fender nicely. The mount I used on my Colorado would have worked if there wasnt the little offset there between the fender and hood.
Same mount I have. I have used it on 3 vehicles I have not mounted it on the 4runner yet, but might before too much longer, it should work fine.
Would you mind grabbing some measurements so I can double check?
Or see how it sits on the fender? Id like to use the fender bolt closest to the cowel.
I have this on my runner, perfect fit i just un bolted a bolt from the fender under the hood. and used that works great, just make sure you have a spring between the mount and the antenna. I'm using a 4' firestik, and it's working out great! just gotta take it off to clear the parking garage.
Update...
I ordered this
It is not a simple bolt on application. The mount does not account for the ribs on either side of the fender bolt. I was able to modify the mount to make it work, though.
