CB Help
Are either fo the two antennas tunable with the adjustable tip on the end?
No, neither of them have an adjustable tip. They can be tuned by removing some wire from the top. I don't feel like they are even close enough to justify it at this point.
The 4’ antenna at 1.4/2.2 is close. You will not get a 1.5 to 1 ratio out of it but you should be able to get a 1.7 or so out of it. The smallest adjustment to the tip of the antenna makes a huge difference. The SW value will move relative to each other so as the 1.4 value increases the 2.2 should drop as you tune the antenna. I personally would spend a few more bucks and get an antenna with an adjustable tip.
I agree. I just had this one laying around so I used it. Plus, maybe I'm just being anal about it.
x2 on spending the extra $ and get a tuneable antenna. I get being anal and trying to solve the issue but you also want something that is easy to work with. Over time you may find you need to tune it again and having to do this crap all over again could be a pain. With and adjustable it takes about 5 minutes.
I actually kept my SWR connected inline on mine and it sits in the glove box at all times. I can always do a quick check before I head out on the trails to make sure i'm set right for a trip. And with the tuneable antenna it's' a snap.
This is exactly what I'd like to do. I plan on buying a new one this week, and I'm sure it will help out.
pax at 4
