CB install writeup
Laubage
Just installed my CB this last weekend with the help of Reata. Huge thanks to him for showing me how to rip apart my car. This was my first mod and it went relatively smooth.
PARTS LIST:
- Cobra 75WXST CB radio
- 12' of RG-8x coax cable
- SO-259 female/female barrel connector
- Diamond K400 3/8C lip antenna mount
- Firestik stainless steel antenna spring
- 3' Firestick II antenna Tunable Tip
- coat hanger for fishing the wire through panels/carpet
- zip ties
- liquid electrical tape
- Automobile fuse jumper (to plug your CB into the fuse box)
- Round wire terminal (for grounding the control box to a bolt)
STEP 1: Attaching the antenna mount
To do this, all you do is follow the instructions provided with the Diamond K400 mount. There are 4 set screws that hold the antenna mount to your car. Originally, we put a spacer between the set screws and the vehicle to protect the vehicle, but I later figured out that the set screws HAVE to drill into the paint in order to ground your antenna to the vehicle chassis. You can see how we attached the mount here:
232323232%7Ffp%3B%3C5%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557447%3B85339nu0mrj~original
STEP 2: Routing the antenna mount cable into your vehicle
We chose to route the Diamond K400's 6' attached cable through the wire shafts that are underneath the top of the liftgate. To do so, we started by squeezing the wire under the spoiler lip until it circled around underneath the liftgate.
232323232%7Ffp%3B47%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557444%3A%3B7339nu0mrj~original
From here, we used the wire holders that came with the K400 mount, along with zip ties, to hold the wire in place. Once we got to the wire shaft, we cut into it using wire cutters and squeezed the mount cable through it. Routing the wire through here makes it come out of the roof lining. After we routed it into the roof, we sealed up the hole we cut in the wire shaft with liquid electrical tape. Use your coat hanger to fish it through the ceiling.
232323232%7Ffp%3B%3C7%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557448%3B5%3B339nu0mrj~original
232323232%7Ffp%3B%3A3%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D355744%3A836339nu0mrj~original
Once it's in the ceiling of the car, you can squeeze the rest of the wire into the edges of the lining to get it down to where your jack compartment is. It is in this compartment where we attached the 12' coax extension cable.
NOTE: If your extension cable is a male/male extension cable, you will need to attach the female/female SO-259 barrel connector between the wire coming from the antenna mount and the extension cable.
232323232%7Ffp%3B%3B9%3Enu%3D3557%3E4%3C4%3E%3B%3B%3B%3E26484%3C4%3C%3A%3C248ot1lsi~original
STEP 3: Routing the extension cable
Once the extension cable is attached to the antenna mount wire, you can start routing it along the drivers side of the car. To facilitate in this, I suggest you do the Antman storage compartment mod. This will help you see where the wire is going as you route it.
232323232%7Ffp%3B68%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D355744955%3B339nu0mrj~original
The first place you will route it through is the rear passenger door panel. To open this, all you do is pull on the panel and fish the cable through. Once you do this, you will want to pull off the door step in order to route the cable away from view.
Note: To do this, you simply have to pull/pry the door step off. There are some white plastic clips that hold the part to the car and if those get detached from the door step, you just simply have to put them back on under the door step before replacing it.
232323232%7Ffp%3B8%3A%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D355744%3A%3A43339nu0mrj~original
232323232%7Ffp%3B66%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557447%3B88339nu0mrj~original
Keep routing the cable up to the drivers seat by pulling the driver's door step off as well. We left the side panel between the from and rear seats there and simply stuffed the wire underneath it to get it behind that panel. The panels aren't pulled off in this picture because we forgot to take another picture, but this is what you're dealing with.
232323232%7Ffp%3B7%3B%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D355744%3B7%3C2339nu0mrj~original
Once you get it up to the driver's seat, you will be able to run the extension cable straight from the drivers door step to under the carpet. It looks like this...
232323232%7Ffp%3B%3C6%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D35574469%3B7339nu0mrj~original
From here, you will have to route the cable under the carpet to where the other seat anchor is, next to the center console. To do this, you gotta do some more fishing with that magical coat hanger.
232323232%7Ffp%3B89%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557449745339nu0mrj~original
Once you get to the second seat anchor, you have to wait for it.... fish it again, but this time up to the center console. You will have to pull your center console apart to do this first.
STEP 4: Pulling your dash/center console apart
There are probably a lot of other threads discussing this topic, but I will explain it here. You start by pulling on the side panels that surround your air conditioning control panel and your cubby holes. Start by pulling the panels in the direction of their respective seats (driver/passenger) working your way from the bottom on up to the top, as the clips come loose.
Note: You will have to pull harder than what seems natural for these parts to come off. There are also little yellow clips that hold these in. If one falls off in the process, don't worry, you can reattach it to the panel.
OPTIONAL STEP
Next, we removed the bolts that hold the A/C control panel in place, but I'm not sure this is necessary. Once the bolts are removed, there will be a plug and plastic clip that holds the plug in place behind the unit. Just unplug it and unclip the unit.
OPTIONAL STEP
Now there are two screw that hold the liner that runs along the side of the center area (where you shift). We removed both of these to facilitate our routing of the coax extension cable into the center console. Once again, I'm not sure if you NEED to do this. There's one on each side and this picture is me removing one of them
232323232%7Ffp%3B99%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557448%3A6%3B339nu0mrj~original
Once this is done, you can remove the center console by unscrewing the knobs for your shifter and your 4wd knob. Just unscrew counter-clockwise. Once this is done, pull on the framework of the center console to remove it. Once again, it is attached by clips, so you might have to pull to the point you feel like you're breaking it. Do this, and pull the center console open. There will be a plug attached to it that you will have to unplug. It is just the wire that goes to your rear window switch. After it's all done, your center console will look like this:
232323232%7Ffp%3B57%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D35574476%3A7339nu0mrj~original
STEP 5: Installing the CB radio
Now that the dash and center console are apart, you can begin looking for places to mount the control box for the Cobra 75WXST. Keep in mind that wherever you chose to mount it, the wire that the handset attaches to is only 6" long. This is why Okki ran into trouble trying to get his handset plug to where he wanted it (Thanks for the lesson learned Okki! :hatsoff:). He ended up getting an extension cable, and you can too if you can't find a place that works for you.
We chose to mount it forward of the 4wd shifter, under the cubby hole. And we attached it to this position using zip ties, with the 6" cable running to the front of the car and the power cables running to the rear of the car. Here is a picture of it installed. The black cable you see running to the control box here is the coax extension cable.
232323232%7Ffp%3B4%3A%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557447393339nu0mrj~original
Eventually I would like to mount the handset connector to the side of the dash under the glove compartment (as it's shown here). But I will have to wait for someone smarter than me to figure out how to mount that plug to this panel.
232323232%7Ffp%3B45%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D3557449564339nu0mrj~original
Until I figure out how to mount it, I just connected the handset to it and ran it out of the right side of the center console. Just like Phillyd2 did.
CB5.jpg~original
STEP 6: Routing power to the control box
I don't have any pictures of this part, because we forgot to take any :dammit: but we routed the power line down the left side of the center console, under the carpet, and up around the foot pedal area. This is real easy, as the carpet is attached under the foot pedal via velcro.
Connect your fuse jumper to the red power wire coming from the control box.
Once done, there is a fuse box just above your parking brake. We used our automobile fuse jumper to attach the red (power cable) to an unused fuse port (identified by an empty box with a slash through it on the fuse box cover). This will provide it power, when the key is turn to the "ON" position, but not the "ACC" position.
Next, we crimped a round wire terminal to the black wire (ground). This allowed us to bolt it down using one of the many bolts that screw into the metal chassis of the vehicle.
STEP 7: Test run
Attach your Firestik antenna to the Firestik SS attachment, and then to the antenna mount. Now power up your car by either starting it or turning the key to "ON". Turn on power to the CB using the handset, and see if you can hear/talk to anyone! In neighborhoods you might not be close enough to many people, but once you hit an interstate, your radio will jump to life.
STEP 8: Close everything up!
Before you close everything up, you can/should attach an SWR meter to the setup, to verify that it is working correctly.
Once all this is accomplished, YOU'RE DONE! :reddance::drummer:
Thought that picture looked familiar. After having it there for more than a few months I see no reason to move it. It's handy and completely out of the way of passengers.
Great write up :trophy:
So now that the forum works.... :doh:
What are you guys that are using the add a circuit fuse taps doing with the fuse box cover?
I have a Mr. Murphy attitude and want to be sure I don't lose the cover that has the fuse diagram on it.
BTY here are photos of my CB install:
http://rhino4runnersuspension.shutterfly.com/pictures/2551
I cut a slot in the cover with an exacto knife for the fuse tap. I used one of the old school brass mini fuse taps and trimmed it to fit our low profile mini fuses where there was an unused fuse and just have the spade sticking out of the cover. It just switches my relay on my extra Painless fuse box.
The same diagram is in the owners manual.
Great writeup, quick question...
I am going to install 2 ham antennas this weekend, both with Diamond K400 mounts. WRT the boot, did you cut a slit in it and put the whole PL-259 connector through it?
I have to run 2 coax cables and one small control cable for my screwdriver antenna...
Again, great work and thanks
Yea, I did... The rubber kind of stretches, so you should be able to get the whole connector through without making too big of a hole.
Good clean mount...let us know how you like the CB, I had one in the past in my Tacoma, and it was very finicky.
I was going to do mine like [MENTION=68685]Ducmonsta[/MENTION] but depending on what I hear about the current version of this cobra, I may consider it.
[MENTION=73580]Laubage[/MENTION] - Thank you for taking the time to post the pictures, process and part numbers. That info is very helpful.
Now that it has been on for some time, do you notice any rust issues with the K400 mount? I'm very interested in the mount, but there were a few folks complaining of rust.
Thanks again!
Thanks again!
So I actually just relocated the antenna mount to right above the left tail light and switched the antenna to a 2' Firestik so that I could park in my garage without removing the antenna.
The area that I had the old mount did have some rust due to the bolts screwing into the point. There was also a little bit of rust on the opposing side of the mount from the mount hitting the car when the trunk was closed. The rust was nothing major. I just used some Perma Blue (from my gunsmithing supplies), dabbed it on there and then just put electrical tape over it... definitely no science behind it, but I at least feel better about it! hahaha
I also went to a local CB radio shop to get my Cobra radio/antenna peaked and tuned ($50). The CB now puts out 4 Watts, swinging to 10 Watts when being spoken into. It was 2W swinging to 4W when he started. My reception is great now... I don't know how far it goes, but the two random times I did a radio check, I got a clear response :). The best part is I never have to take off my antenna!
Oh yea, last bit... I did replace the heavy duty spring with a light duty spring, so that every time the antenna hits something, it doesn't warp my mount. Here's the link:
http://www.wearecb.com/aud306-light-duty-spring.html?desktop=
DionicioLives
