CB or HAM in your Rig?
Only a CB setup in my 4th gen for now but eventually I would like to also have ham radios in both runners. May have to get that handheld though. May be good enough for what I do.
This $30 radio from Amazon is plenty amazing! I think everyone should have at least 1 if not 2 or 3...
http://amzn.to/1Lk6QJj
Something like this used to be $150-$200, and that would be difficult to suck up as compare to the $50 CB. Now, these $30 ones just make it all possible and affordable.
This radio can be mod'ed to do all those that I mentioned before, ONLY lacking the best-in-class high-gain antenna and the transmit power. But this is a handheld... not a car-installed setup....
Those little Baofeng radios are a great deal. The stock antenna is garbage, but there are plenty of good inexpensive replacements on Amazon. It's also a pain to program on the fly, so I use it as a backup/monitoring radio. I use a yaesu ft-2900r for most communication which at 75w has an exceptional 2m simplex range. I also use a bendix/king eph radio for a lot of 2m handheld stuff. They are primarily used for wildland fire service, but are extremely durable, have great audio, and can be picked up for cheap on ebay. Although these need to be modified for use on the ham band which can be done with a computer. Most trail communication is done with either cb or frs radios. I primarily use the ham for side talk with any other hams in the group/emergency communication. It gives great peace of mind being on the trail knowing rescue is only a key up away.
I just run a Cobra CB. The one that's all contained in the mic. It's all I need. Only use it for the trails when everyone is pretty close to each other.
I run a Yaesu FT-2800 in the dash. I also picked up a Baofeng dual band radio and am loving that thing. Picked up cables for both it and the Yaesu and do all my programming with a laptop. Both great radio's.
I have a CB, and was going to install it, but honestly we just don't use them that often anymore. The channels are always cluttered with crap and once you get a little bit of distance (like we always do in the desert), you loose contact real quick. I do have a Midland 75 handheld if I need it, with a lil-wil mag mount.
Where did you get the passenger side dash mount that goes behind the center console? Thinking that might be a good solution for a UV5R mount.
The FT-2900R 75 Watt Heavy-Duty 144 MHz FM Transceiver seems to be the best currently available option for a wheeler.
What is the best mobile antenna and mount?
Why do you say that? Is it JUST due to the 75W output?
I personally think a VHF/UHF dual bander is better..... just cuz you can talk to FRS/GMRS if necessary
I like Diamond's antennas. I use their motorized mount, so that I can lower my roof mounted antenna to get into parking garages etc...
I personally think a VHF/UHF dual bander is better..... just cuz you can talk to FRS/GMRS if necessary [?quote]
Which one?
I use Yaesu FTM-400D, 50W, dual band, dual monitor, X-band repeat (so I can run it like a localized repeater around camp or to support tactical deployment of something like a SAR incident), VHF can be programmed to hit MURS, VHF business-band, USHPA frequencies, marine frequencies..... UHF can be programmed to hit FRS/GMRS, UHF business-band, etc..
I found this nice list online:
https://radiofreeq.wordpress.com/20...iness-weather-marine-ham-channel-frequencies/
Thanks, looks like more reading is order...
.... on a motorized antenna mount - Diamond K9000LRM (folded down when not being used), mounted on the roof within a Gobi roof rack (having the front lights protecting the folded down antenna), a 38" Diamond dual band antenna NR770HBNMO (3.0/5.5 dBi gain)...
Do you have any pictures of the antenna setup? did you ran the cable towards the back?
I am working on there write up and will post soon.
I run the control cable (for the motor) and the antenna cable under the passenger side windshield weather strips.
My antenna lowers horizontally, from the passenger side towards the driver side.
(hope that these pics come thru)
Sweet ride...
So somewhere you posted you radio is modified, can you explain how,,,I am very interested and the multi band and repeating aspect is very attractive.
By the way, I had a commercial license for a 500 watt repeater, 300 antenna on just about the highest point in Arkansas until 2001...I could reach multiple states and regularly talked to maids, working in St Louis who had in house radios on the same frequency...illegally, but the were a fun bunch of horny women so I never complained...The system was an old tube radio system set for doctors by a Motorola dealer. He sold it to me for almost nothing when cells became efficient when I bough digital mobiles for my farms and a few friends.
My ex-wife, who was responsible for handling all the farm bills from her expense account, failed to pay the fees...it was likely the last repeater license at the power that will ever be granted and was in service to a non-law enforcement agency...wonder why she is my ex?
Wow, gorgeous rig!
I nee!d to update my 2m/440 radio. It's ancient. As much as I'd like both a new dual-bander and separate HF radio in my vehicle, I haven't convinced myself its worth the effort to cleanly install and rig out two radios. Time will tell.
Great images, nice clean setup. Thanks for sharing.
Almost any radio you get now can be modified (simple mods) to do open rx/tx. You would have to look into that for your particular model of radio.
Generally, the open tx mod will allow tx at 137-174MHz, and 420-470MHz.
"X-band repeat" is a less supported features, in order to support that, your radio unit basically needs 2 radio inside, one locked onto VHF and one locked onto UHF...... and RX-VHF and TX-UHF; and RX-UHF and RX-VHF... that is pretty demanding on a radio.... but very useful....
Can you recommend radios where this is easy and knowledge readily available?
As well will I catch heat for running a dual band with only tech license from the ham club cops?
