CEL bombardment
Mudeprived
Hi it has been a while since I been here. I wanted to ask you guya for some help on an issue that popped up while my mother was borrowing the truck. I got it back from her and the CEL light popped on. I got four codes from it:
p0125
p1130
p1135
p1135p
I plan on replacing both up and downstream 02 sensors on the cat with denso
234-4153 and 234-4162 sensors if those are the correct ones. That is what I have read could be the issue and the truck has 158k miles on it so they are due. Is there anything else I should look into?
Chris
99 Limited v-6 4x4
Could be a/f & 02 sensors.
FSM says to check pcv valve and hose first.
Then check sensor connectivity to ecu.
Then check a/f voltage to specs.
Luck. :cowboy:
I have the same EXACT codes right now. I went through and checked all vacuum lines (and found a few cracked). I found that both a/f sensors (I have a cali version) were dead and I'm replacing those. I cleaned my MAF. Hoping these things will eliminate the codes.
Did you replace the cracked hoses? If so what did you use to replace em with? I have not had any luck with the rubber hoses at the parts stores. They seem to dry out and crack quickly.
I guess I'll see how these last. I used vacuum line from Napa that seemed to be nice. If that doesn't work out I'll try to go ahead and get the OEM replacements. I do feel OEM is always the way to go, I just wanted to try this first.
2001ATL
