CEL P0420 - CAT deficiency
My truck was originally purchased in maryland. Do i assume its not a cali or would it be stated on the window sticker? Would the owners website have specific info? I am on a fishing boat today so dont have access to the owners site.Lot of traffic before raleigh. Stopping in tarboro to get a burger
Mine was purchased in NJ (it's a Cali.) Most 2000's were Cali/s regardless. It is NOT on the window sticker,IIRC. You have to look at the emissions label under the hood or count cats (2=Cali, 1=49state). Not sure about owner's site.
Ok, so a couple points:
1. Denso in the OEM supplier for these O2 sensors. It is suggested that you ONLY buy Denso as Denso's proprietary material in the sensing element seems to be better than other brands.
2. Stick, I totally understand your point about loyalty to a local store. I was like that with a local motorcycle shop (until he closed down, I think he got out of the business). I also respect if someone can offer an item for something like half off what conventional stores charge, because especially for things like O2 sensors, which are mildly expensive, it allows low income people to save alot of much needed money on auto repair, especially if they do the work themselves.
If you can afford to be loyal to a local shop, then awesome, I won't criticize you for it, but I wouldn't suggest that to newbie's as they will likely end up getting ripped off by a shop that isn't deserving of their loyalty. I will be loyal to a good shop (like that motorcycle shop), but I havn't run into many shops deserving of such loyalty.
3. OP, read this thread for alot of background on O2 sensor part numbers
http://www.toyota-4runner.org/3rd-gen-t4rs/81424-denso-o2-sensor.html#post699825
BTW, this is linked in the Tutorial and documentation sticky at the top of the 3rd gen sticky.
There is a link in that thread to the URD guide which seems to be pretty spot on. The denso website didn't seem to be the easiest to me, but the URD site is pretty easy to read.
4. T4R_finally: The easiest way to tell is to get under your rig and count the CAT's. Click the link I posted a you and there are some pics from TheDurk showing both CAT's.. If your's looks like that, then it's Cali; if you only have 1 CAT, then it's federal.
Gotcha guys and thanks. I am buying denso, its just a matter of where from. I am finding many for under 100 bucks but not sure if gasket is included or not. When i get home, i will check cali or not and order the right part and gasket.
Not sure i am real keen on that youtube video, though, where the guy says run a gallon of lacquer thinner thru a tank of gas.
Not worried about keeping my dealer happy over an 02 sensor. Didnt buy this truck from him but did buy a new 5th gen earlier this year, so he should be happy for a while. If he was down the street and had the parts on the shelf, i might do it. But not worth the gas and the drive if i can have it delivered to my door and install myself.
$60 on amazon, and it comes with a new gasket. I think Denso includes the new gasket, so you shouldn't have to worry about that.
Correct, as the emissions info. IS right on the window sticker. Mine for example, is a 2000 Limited and my window sticker says CA(Code) for California Emissions.
I may be confused. Are you talking about the annual (or biannual, whatever) inspection sticker or the original sales sticker on the car when new?
I was talking about the original window sales sticker which I lost a few years ago. Inspection stickers are different for each state, of course, and I can assure you that here in NJ the inspection sticker has a serial number and an expiration date and absolutely nothing else. No codes, no VIN, nothing. It used to have the plate number but not this latest one...I just looked.
Sorry for the confusion, I was referring to the Original Window Sticker, This one:
Uploaded with ImageShack.us
Hmmm...I really don't remember seeing that in 1999. I think I would have asked about it if I had noticed it. As it was, it was a minor shock to find out I had a Cali. when I got my first o2 sensor code at about 70k. I wonder if they had it listed in 1999 as well. I suppose so, if they were getting $340 extra for it--I just never noticed it.
Got home and checked my window sticker and the first item listed under optional equipment is "CA Emissions". Looked underneath and saw the 2 CATs. So, found the right part on "fleabay" for $62.30 shipped and ordered it today. Fingers will be crossed that this helps. Sensor in there now is apparently the original. The part of the gasket that is exposed around the edges practially crumbles when you touch it. The A/F sensor in the front looks like it is newer. Not a recent replacement but doesn't look like it's been there as long as everything else in that area.
Thanks for the help.
youngrk
