Center cones- leave in or out?
01PArunner
When I lift my Runner, can I reinstall the rubber center cones in the rear for a small amount of extra lift or is it best to leave them out when reinstalling the new lift coils? Is it better just to add 10mm trim packers with the 890 or 891 OME springs?
The bumpstops are an important part of the suspension system. They prevent too much compression and give a 'softer' feel at the end. Without them, the shock could bottom out and be destroyed or the coil will go solid and be damaged.
Use the trim packers to adjust ride height if one side sits lower than the other, or put them in for extra lift on both sides.
I'm not talking about the bumpstops! I'm talking about the center rubber cones that fit inside the center of the rear coils! I believe that the earlier years of the 3rd. gen. didn't have them in to begin with. Mine is a 2001, so my runner has them.
I have them in my 2002 as I suggested earlier and as we all have said you need to leave them in or your will have a rude awakening when they aren't there to stop the spring from full compression. I even have the 10mm trim packers just make sure it goes spring trimpacker with the rolled edge up then your bump stop and install.
and yes they are bump stops! don't back talk!
Thanks for clearing that up for me, rdgt4r! What rear springs are you using in your rig?
Its been so long i cant remember that should be about right though. Its hard to tell now as i have the suspension lift, bl, and 33.3" tires now.
Do you have any new pics with the body lift installed? I'd love to see them! It seems like this 4-Runner modding can be addicting!!
I see you finally got the BL!! I wanna see some pics, your runner has to be looking pretty sick now.
