Presta24
Finally got around to changing the diff fluids today. Used a bottle pump and Mobile1 75w90 LS syn. Made quite a mess but got er dun. All except the front diff. The plugs are so rusted I cant even get the hex bit in them. Just gonna have my buddy drain and fill it when he does my trans flush. Runner has 109k on it. Rear pumpkin oil was a little milkshaky and pretty thick. Center diff was dirty but looked good. I would expect front to look similar to center (V8 awd). Word of advice....take it slowwww with the bottle pump. Builds a lot of psi with the thickness of the gear oil. I went at it like a 16 yr old on prom night at first, and blew the outtake hose off. Pump worked great once I geared it down a bit. Rear pumpkin took right at 3 qts, center diff took a little more than 1.5 qts. This is the pump I used, got mine at the local O'Reilys for $12....Mityvac MV7241 Fluid Transfer Pump | eBay Next I ran the seafoam through the intake. Smoked like crazy. Hopefully a little better mpgs, and a little better throttle response maybe.
