changing the VSV switch
matthinnant
So I have the notorious p0466 code and I believe its my VSV switch but I came up on a few of them I know my 01 has 2 vsv switches one on the charcoal canister which is new from junkyard so im going to try and change the one under my hood but when I looked and pulled up the numbers I found that theres 2 under there. Im going to you guys the numbers I found and if you could let me know which ones I need. The last two I put on here are the ones I actually found on my truck so what does the first one go too??
25860-75160 - OEM Toyota VALVE ASSY, VACUUM S
25860-75230 - OEM Toyota VALVE ASSY, VACUUM S
90910-12245 - OEM Toyota VALVE, VACUUM SWITCH
Look at your link. The first one goes on trucks from 2000 and earlier. You have a 2001.
AndiGarage
