Well, I did a search on here to see what was involved in changing out the serpentine belt on a V8. I noticed a lot of people having issues with belts/pulleys on early '03 V6's, but not much talk about changing it on the V8's. Since my V8 has 54k miles on it, the belt was starting to look a little 'weathered' and showing a few dry-rotting cracks on it. Since I'm taking a 6,000 mile road trip in less than two weeks I figured I would go ahead and swap it out just for safety sake. All I have to say is that it was a very easy job. The hardest part was making sure the belt got wrapped around the crank pulley properly, as the clearance down there was very minimal. Small hands would definitely help a lot to do this job. A 14mm socket and ratchet on the tensioner and the original belt came off in literally 10 seconds. 10 minutes of fighting to get the new belt over all of the accessory pulleys, and I was done. Very easy job.
I thought I'd just let everybody know that it's about a 10-15 minute job total if you're doing it by yourself. Expect to scrape up your arm a little bit on the cooling fan when reaching down in there to get the belt on properly over the crank pulley, but other than that it was a cake walk.
Ricky
Ricky
