rep4runner
I am in the mountains and almost 100 miles from a toyota dealer. Can the following engine light codes cause the car to barely run? Codes P1135 P1130 P0125
Dr Z's OBD Reader Codes List
P1135 Pedal Position Sensor A Circuit Intermittent
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
I would think, YES
I should mention mine is the CA model, so how do I know which sensor is bad? The downstream one has oil and stuff on the wiring harnesses while the front one is clean. But from what I've read, it is usually the front one that goes bad. NEED TO KNOW ASAP so I can get it smogged and registered thanks!
Again, P1130 and P1135
