Check Engine/VSC TRAC/VSC OFF Lights
Lakesurfer
Hopefully someone out there can help me avoid a trip to the dealership!
Below is what has happened and what steps I've taken:
(1) Battery dead from leaving keys in ignition; unable jump with cables and assumed battery needed to be replaced (4+ years old)
(2) Replaced battery - 4Runner started, but check engine light, VSC TRAC/VSC OFF lights illuminated and vehicle was in limp mode
3) Checked the codes - P2118, C1223, C1241 & C1201 came up
4) Based on code P2118 it led me to a blown fuse - replaced ETCS fuse and vehicle is no longer in limp mode but the check engine light, VSC TRAC/VSC OFF lights are still illuminated
Any suggestions of what to try next would be appreciated! Cheers!
Update (Edited Post - Issue Resolved) - I disconnected the battery for 5 minutes and reconnected it and the check engine light, VSC TRAC/VSC OFF turned off.
Vehicle - '03 4Runner SR5 V8
Had this issue on a 3rd Gen. I tightened my gas cap a few clicks. After a few starts and driving around a bit the lights have gone off.
AndiGarage
