Chitown's 97 T4R Build, "Walter"
i'd name my truck wilson
WILSON!!!!!!!!!!!!!!!!!
I started in with my stereo, picked up everything that i need and its going to be pretty awesome...
Simple Parts List:
Alpine W505 Deck
Alpine PXA H701 Processor
Massive Audio Nano amps, NX4 (2) and NX3 (1)
Morel Supremo 9's
Morel Supremo Piccolo's tweeters
Morel Ultimo 12" Sub-woofer
This whole install is going to be custom, no factory locations are going to be used at all.
Tonight I started into the Kick Panels
Made Rings and Routered and Camferd the edges.
2011-10-28_07-03-09_777.jpg~original
I used low temp foamed plastic to make a sunken edge.
2011-10-28_07-03-00_612.jpg~original
I used Hot glue and dowel rod to mock up the angles and where everything will end up sitting.
2011-10-28_07-02-36_518.jpg~original
And here is one sitting on the drivers side.
2011-10-27_18-05-47_383.jpg~original
NICE! I love a good sound system. Think that will be next on my list. What are your plans for the sub?
The sub is going to go on the back passengers side panel.... But before that happens, I want to see what I can fit in the dash if the Airbag and glove box is removed........ More on that later though....
Be careful with that. I'm not sure how Illinois is, but I know in Cali it's a HUGE fine to take out the airbags.
no offense but what is the point of putting a sub in the dash. it would make more sense to just keep them in the back and dyno out the whole truck.
Because when you are listening to music it sounds stupid when all the sound is up on the front stage like it should be but the sub bass is banging away out in back.
Lots of people say that you can't locate Sub Frequency's below 80hz. I think its fubar and I can hear it... Which is why I am putting 9" mid range drivers in my kick panels to play most of the mid bass up front where it should be...
here is a picture from my last car....
DSC_0025-1.jpg~original
Productive weekend for working on the car. Layered up the Kicks, Modified the rear seat to clearance for the amp rack, created the Amp rack and coated it in truck bed liner for durability and rust / short proof.
So here are the kicks... They are coming along...
DSCN0857.jpg~original
2011-10-31_06-58-26_177.jpg~original
Here is where the amps are going under the rear seat. Originally they were going to go under the driver seat, but this spot is much better and it will fit all 3 amplifiers in one spot and conceal all the wiring as well.
2011-10-29_11-40-02_591.jpg~original
2011-10-29_11-39-26_413.jpg~original
in order to build the seat back up and clearance the seat bottom 2 inches to clear the amps I had to fill that hole back in. I welded a piece of angle over the top of the hole and then glassed in the rest.
DSCN0860.jpg~original
DSCN0862.jpg~original
DSCN0863.jpg~original
DSCN0864.jpg~original
The next part was building a simple tiered amp rack that would hold 3 amps very securely. I off-road this truck and need everything to be really tight and installed with out compromise.
DSCN0866.jpg~original
DSCN0869.jpg~original
2011-10-31_06-58-42_714.jpg~original
DSCN0867.jpg~original
DSCN0868.jpg~original
I changed my mind on the Source Unit...... HEHE.... Anyone want an Alpine W505 head unit already wired up for a toyota install? Just plug it in!
STEREOFLOW-1.jpg~original
Wrapped up the install. Still need to put down some color on the kicks but black works for now. Sounds Super awesome, but the kicks are so big that it makes the car hard to deal with on a day to day basis... might have to switch it up or move something to do the doors..
Went with my old deck and RUX controller Stuff has not been used in 4 years..
DSCN0874.jpg~original
DSCN0875.jpg~original
Mounted the Brain box on the under side of the passenger seat.
DSCN0876.jpg~original
Ran power wire and hooked up distro blocks..
DSCN0887.jpg~original
Covered the modified seat bottom for aesthetics.
DSCN0889.jpg~original
Installed the amplifiers in their new home. Still need to make a trim piece to clean this up, but with the seat down, they can't be seen and its super stealth.
DSCN0899.jpg~original
Wired up speakers and installed tweeters.
DSCN0896.jpg~original
DSCN0897.jpg~original
DSCN0893.jpg~original
DSCN0898.jpg~original
DSCN0892.jpg~original
Everything looks clean, you are very talented when in comes to that sort of thing, but you must be a small dude in order to be wiling to take away that much leg room while driving. I have long legs and need to stretch out.
Nice GR...
