Clazzio seat covers w/coupon floating around tacomaworld
ok, one more question..passenger side rear cover..how is the seatbelt supposed to go through?? Do I need to unbolt and reattach?? Can't see how it would work otherwise.
Yes, just remove one bolt (floor of 4Runner and reattach after the seat cover is installed.
Lots of fun installing these in 90+ degree heat with nearly 100% humidity..The instructions weren't the best, but my emails to the company were answered quickly and with some help from folks on this site I got them installed. They came out pretty good.
Very nice! Same situation with the heat and humidity in south central FL. I went through about 2.5 liters of water while installing mine.
my order has shipped and fedex shows it to be delivered today
that is awesome!
I paid expedited to have them made in the US but I did not think they would come in 16 days!!
i will. thank you
honestly i am dreading it a bit. 100+ temps.. i will be sweating like a pig!`
you are referring to this video correct?
YouTube
actually its this one, b/c you only need to know the tricks n tips on how to get the headrests on, and how to get the leather holes around the plastic bits.
YouTube
I installed just the passenger seat last night. It’s tough when it’s still a hundred degrees at 11 at night and 110 in my garage.
Oh well :)
Maybe I’ll do driver seat tonight
I’m happy with it though!
So hot outside I have stalled. Plus wifey had the truck out for a week camping while I had to work.
Installed the driver side tonight. Just have the rear seat to go.
Curious... I can’t seem to get the front bottom of the driver seat to stay tucked under the plastic cover. Is this normal for anyone?
Secondly. For those that have had them on for awhile, do they stretch out and lay smooth flat agains the back of the seats? Like on the seatback centers, if that makes any sense...
Like here on the light gray portion. It doesn’t follow the tailored bolster of the seat but stretches across it perhaps a half inch or so above the actual cloth seat.
you'll probably have to adjust it a little to get the seat cushion to fit where it wants to.
As for the seat back portion, it will eventually conform, but it might take a while. My driver seat has conformed to the seat back, but my passenger hasn't....since it's not in use everyday. I thought about sitting in the passenger seat while I chill during lunchtime at work....but you know how that goes, laziness gets the best of us.
yeah.. i just had pulled too much of the cover thru the back of the seat and then cranked the straps tight..
i pulled some out and got the cover adjusted right and then cranked the straps back and its all good.
thanks
ok i have everything done except for the rear passenger seat.
dumb question possibly but how do i unhook the seat belt to run it thru the hole in the top of the cover?
should i unbolt the entire assembly from the floor and pull it thru that way?
thanks!
thanks!
If i remember correctly, i had to unbolt it. It was really easy. One bolt
