Cleaned my MAF and TB today. Found that rubber tube that connects is trashed.
airbag
99 V6 Limited
Anyone know what this thing is called? Noticed it was full of sticky crap when I cleaned my MAF and throttle body today. I tried cleaning it myself with simple green but couldn't seem to get it all. More sticky gunk closer to where that tube that connects to it. I'm thinking ill replace some of the cracked and weathered vacuum lines I saw too. Do you just buy them individually or can i get long pieces of assorted hose sizes and cut them myself? I feel like the second option would be cheaper and I can try and replace some of the old hoses in my E36.
Is there something like realoem.com for 4Runners? That's my go to for my BMW and saves me tons of time.
1999 TOYOTA 4RUNNER Parts - ToyotaPartSales.com
It's Air Hose #2 (air hose 3.4 LITER, 1999-02, #2 ).
You can get the part number (17882‑62010) at: ToyoDIY.com
You can't use hose lengths because there is a connection for a small hose in the middle of that thing, assuming I have identified the correct part from your picture. (resonator to throttle body #11 in the pic, right?).
There is no realoem for Toyotas. (I have a BMW in my fleet, too.) But with these two you can get close.
Yes exactly that. And thank you for posting those links and diagram. I cant believe I did not find toydiy,com when I was looking around.
As for the hoses I was thinking I could cut to fit, What I am referring to are hoses in the engine bay that haul all the vacuum around. Ran outside just now and snapped a couple pics of the ones I'm talking about. ill put them in a separate post from my phone in a minute.
In to the resonator
Not sure what this one does but it cones out of the upper air hose and I noticed some gooey sticky stuff in the upper hose between the resonator and throttle body.
This one goes to the air filter box and is pretty weathered.
Looks like just simple hose of various diameters.
Not as straight forward as realoem but using the couple sites mentioned above you can get what you need.
Not trying to hijack the thread too much but is there a plumbing option from the throttle body to the maf that would get rid of all the other "OEM" stuff there is not really as much information on it as there was on my first gen pathfinder it had a sticky devoted to just that but any help would be great
There's the resonator and some tube coming from it to somewhere, might be a problem but I don't know enough about what it does exactly.
Mike Sargent
