Cleaned TB and IAC - What I noticed
jimmyrecluse
First, just got my Blue Driver OBD2 scanner, updated it, plugged it in and
0 codes. Not a thing. I love Toyota!
Pulled off the intake and TB and IAC. 1999 v6 4wd, 182k miles. I've had it for almost 5 years and put 40k on it.
The TB was DIRTY. I used an entire can of TB spray and barely scrubbed it clean with that. I also pulled the IAC off, which appears to be factory original. Didn't look too bad but cleaned it anyways.
What I noticed is a stronger idle, stronger shutdown of the engine - much smoother. And also smoother acceleration - this is subtle, The idle and shutdown are very noticeable.
I've ordered the champion 3 pass aluminum radiator. Doing mild stuff before I pick up a Magnuson SC with the base pulley.
is this a direct bolt on part? if so, can you link it?
Dude, you've been here long enough you ought to know this has all been covered time and time again. Use the better search:
Alternate Search for T4R - 3rd Gen Section
and you'll get over 100 different threads on it.
https://www.google.com/search?ei=7qjuXeSaMOyFggfk-6yIDQ&q=champion+radiator+site%3Atoyota-4Runner.org%2F3rd-gen-t4rs%2F&oq=champion+radiator+site%3Atoyota-4Runner.org%2F3rd-gen-t4rs%2F&gs_l=psy-ab.3...10555.13759..13936...0.0..0.116.1317.18j1......0....1..gws-wiz.ZUfkzr8bM7U&ved=0ahUKEwjkydbJrqnmAhXsguAKHeQ9C9EQ4dUDCAo&uact=5
There are at least 2 youtube videos out there too, one from Timmy and one from sleepydad (IIRC) showing you everything you need to know.
It's Mostly bolt-on, depends on your specific truck (and maybe the specific radiator) as to how much, or little, modification is needed. Mine needed 2 tabs cut off, took maybe 15 seconds with a hacksaw and done.
SUPPOSED to be a direct bolt on but from what I understand, it's "close".
The fan shroud doesn't fit perfectly and must be either bent slightly or -
Inside the bolt flanges for the fan shroud are tapped in threads, I know at least one guy who removed those to get the fan shroud lined up.
the mounts for the radiator apparently aren't perfect either but will a little mod with a Dremel ends up working
Security Check
slow down cowboy. i wanted to ensure we were talking about the same thing.
i am aware champion makes a radiator that says its for a 4runner. when i searched last time i couldnt tell if it was a direct bolt on or if it needed to be modded. i even wrote them and i never heard back.
i have not seem tim's video. i will look for it. thank you.
It's supposed to be a direct bolt on, but some people have said that the bolt holes don't line up with the captured nuts for installation requiring you modification. I don't have one so this is just what I remember reading about it with no first hand experience.
Cpn2mss
