Clear corner help
Park
Hey guys, I am looking into buying some clear corners and I found these, the weird thing is that the light is LED and I haven't ever heard of those from you guys. So do any of you have these? Are they good quality? And will they just plug right right up even though they are LEDs?
As far as the quality of the lights, not sure how well they are made. Running the factory ones. The LEDs won't get as hot as regular bulbs. They usually don't require as much power to light them up either. Many people switch lights over to LEDs cause the bulb life will be much greater on LEDs. They will probably be brighter than bulbs too. You can always use your old bulbs if you wanted to as you won't be swapping any wiring or bulb holders out.
Hope that helps.
You'll be fine with LEDs, running LED bulbs inside and out on my 3rd Gen. And for the corner lenses, they're all the same as far as quality goes. Go for it! :)
Talyn
