Clinometer App
Porqupine82
I've recently found myself puckering way too early on off camber and slope, and figured I'd share an app I found which helped easy my puckering when on a slope....
I have determined my pucker number is right around 20 degrees :fear:
The app is in the play store, and it's free.. just search "Clinometer" the developer is plaincode... I have no affiliation, but I do find it quite useful.
You can see how it works on my instagram, my IG name is the same as my screen name here... check it out if you like.
If you want to calibrate yourself a bit, (carefully) note the clinometer reading while briskly going around corners on pavement, especially roundabouts. I hit 20 degrees on the clinometer regularly while cornering, and it doesn't feel like a big deal at all. Not nearly as scary as 20 degrees of tilt on the trail. It''s more a psychological thing than physical.
The truck will do 40-45 degrees without rolling, but I could never bring myself to push it that far.
Most I have done that I know is 30-33 at crawling speed and it felt fine, fully stock at the time, no roof cargo.
mek
