close friends 98 v6 runner has burned valve socal
sweet trav
so one of my close friends, pastor who married my wife and I, has a 98 v6 which apparently has a burned valve. will need haeds rebuilt at least. any suggestions for good/reliable shops?
thanks!
thanks!
Oceanside, CA?
My advice don't do a rebuild. Period.
Do a search on here for rebuild and you will hear conflicting things but usually they go like this ...
"Hey I bought a truck and now a few months / years later it runs all F'd up. I think the previous owner did a rebuild several (like 2-3) years ago and it was running fine when I bought it."
First off, most rebuilds cost $3500-$4000 and ALWAYs use aftermarket parts. Sure it will come with a 12 mo warranty but that will do little good one it breaks down 2 years later.
I'd suggest an engine swap. Do a search here on the forum.
Also, a and this is most important, you really don't know what is wrong so take it a good shop that knows Toyotas.
If you are really in Oceanside I can name a few.
he's in vista...I used to live in oside.
any specific suggestions would be great...I've gone both routes in the past...had shops rebuild or drop in used engine but I live in north idaho so I cant help him as much as I'd like to.
thanks!
thanks!
Only way to know for sure is to do a compression/leakdown test. If he had this done then most likely they are right.
I agree he should do a motor swap with a good low mileage used motor.. Find a good donor motor from a running totaled 4runner, purchase, and have one of the toyota shops do the swap. I would have the new motor compression/leakdown checked before purchase also.
