**CLOSED**WeeBoost Group Buy!
Received mine already. Now to sit on the shelf while I finish several other projects first.
Sent from my SM-G965U using Tapatalk
WeeBoost Group Buy!
Welllllll, got my delivery today for the Reach Drive Fleet OTR and the main device is missing! I’ve reached out to the seller by email and VM, but they are not in until tomorrow morning, so stay tuned.
This was all that was in the box:
That's super weird. Mine came in a cardboard over-box, but the weBoost was packaged in a very nice box with a printed slip over the whole thing. The components weren't loose packed either, they each had their own little spot all organized.
Maybe you got a return or something...?
That was my first thought as well. Apparently, these are shipped directly from WeBoost and not the store, so they are going to have to follow up with WeBoost to see what can be done.
UPDATE: They are shipping me a new kit. Hopefully they are able to track the other pieces if they were stolen!!!
Ok I'm in for a Drive Reach OTR. Thanks [MENTION=122940]ramonortiz55[/MENTION] for setting this up and making me spend more money!!!
After I made a comment on another member's post about signal strength, I received a PM from someone giving me a more technical explanation of how to measure signal strength. I think my comment was something along the lines of "So you went from 2 bars to 5 bars for the laymans like myself." Regardless, it seems as though the number of bars is not a good measure of signal strength as it can vary by phone (i.e. iPhone vs Samsung vs LG, etc.). For those who want to dive into a little more, here's the article: How to Check Your Phone'''s Signal Strength | dBm & Top Apps
For those who don't want to read the article, I'll summarize. Signal strength is measured in decibels, much like that of sound. However, it isn't the same dB as sound, but rather dBm. Don't ask what the m stands for. If you cared that much you'd have read the article. but the closer to 0 the better.
Before turning on my WeBoost Drive Reach OTR Fleet model, I was pretty constant at -110 dBm. As you can see on my phone, I had approximately 2 bars (again, arbitrary and not a good measure). This dBm measurement was not constant. It fluctuated a bit. The worst that I saw was -114 dBm and the best was probably -97 dBm. Regardless, -110 dBm seemed to be the "return to normal" after brief changes in signal strength either direction, so that's what I'm going to use as my baseline for the un-boosted signal.
After powering on the booster, it seemed to be pretty consistently -76 or -77 dBm.
So that's an overall improvement of about 34 dBm. and a 38 dBm improvement if you go from worst to best.
I found that signal strength was best when the phone was within about 3" of the internal antenna. My WeBoost owners manual calls for mounting the internal antenna 18 to 16" away from the intended use area of the phone. I did find signal improvement in this range, but not as good as the 2-3" area.
I often find myself using the Bluetooth in my truck and keeping my phone in the cupholder area of the center console. I think I'm going to permanently mount the internal antenna in the area below the AC controls.
Good find. I haven't gotten that far out to really test it, but in the city with 2-3 bars I assumed this booster would give me instant 5 bars and it doesn't seem to. I was worried maybe it wasn't working or compatible with a case (I got a cradle model), but now that I've found my dBm reading I'll have to compare the numbers on and off the weBoost. Thanks!
holy smokes! - do you have to return all the other nick nacks?
added
