Clunking noise after lift
inscarguy
Member
i just had installed the 2.5/1.5 lift. about a week after i noticed a slight clunk/snapping noise during turns. it does not happen all the time and it does not do it going straight. only on lt and rt turns. i checked all the bolts/nuts and they are all tight.
anyone experience this?
did u get a new alignment after the install? check to see if when turning the swaybar makes contact with the anything, if so maybe a swaybar relocation kit or another alignment may help.
i did get an alignment after the install. took it to my local toyota dealer. they gave it their normal go through checking everything and gave a clean bill of health. no problems. all specs are perfect, well within the the specified areas. drives perfectly.
i just went out and checked the distance from the sway bar to the strut and its at least 1" to 1-1/4 " away from the strut.
MaximussK
