clutch fluid change
jaypapa
Unless I missed something, I can't seem to locate Toyota's recommendation on when to change the clutch fluid for the manual transmission in my 2000 SR5 3.4L. I'd be interested at what interval (or if ever) others use.
I usually change the brake fluid every 2-3 years (roughly 30-50k) for other cars I've owned. Would this be an opportune time for the clutch fluid?
I flush mine every year or two on my '97. It keeps the clutch working nice and smooth, and the master and slave cylinders are the originals.
That's one periodic maintenance service that is often neglected.
I also flush the brake fluid on about the same schedule, and the power steering fluid.
How do you do it? I've been meaning to do it and I have never seen a write-up, and I follow this forum pretty closely. I can figure it out, but any tips are welcome.
Just connect some clear hose to the bleeder on the slave cylinder with the other end going into a container to catch the old fluid. Then I have someone push down the clutch pedal and hold it down, while I open the slave cylinder bleeder and quickly close it again while there is still pressure forcing the fluid out.
Then I have my helper let the pedal up slowly, then repeat until the fluid coming out is clean.
Just keep a close eye on the fluid level in the reservoir, as the level drops fairly quickly in the small clutch fluid reservoir, compared to the larger capacity brake fluid reservoir.
For the brakes I use one of these: universal brake bleeder kit
Then start bleeding the system as you normally would: right rear, left rear, right front, left front.
For the power steering fluid I use Mobil 1 ATF. I loosen the pressure line on the steering rack, and let the fluid drain into a bucket. There is a small brass compression fitting inside which the line seals against. Don't lose that. When it's has stopped draining, I re-connect the pressure line to the steering rack, and fill the reservoir with fluid to the proper level.
This doesn't get out all of the fluid, but it gets more out than just siphoning the reservoir.
When you initially start the engine, there will be air the system which may cause a brief whine from the pump, but that will go away quickly as the fluid pumps through the system.
Re-check and adjust the level if necessary, after the engine has run for a bit.
Cool, and thank you for the tips. A silly follow up question: What fluid (brand & type) do you use for the clutch?
The cap on the reservoir says DOT 3 brake fluid only. But I have been using a DOT3 and DOT 4 rated fluid since I bought the 4Runner new.
Any DOT 3 or DOT 3&4 rated fluid is fine.
This is what I'm currently using in the clutch, and brake system: Valvoline.com > Products > Brake Fluids > DOT 4 Brake Fluid > Valvoline® DOT 3 & 4 Brake Fluid
Just make sure you don't use a DOT 5 fluid, as that is NOT compatible with DOT 3 or 4.
Also, don't spill any on the paint, as it is a good paint remover. Wash off any spills immediately.
