Clutch Master Cylinder
Diadora6
Not able to get as much pressure in clutch after replacing master cylinder. I bled it until the air bubbles stoped. Its making it difficult to shift into first and reverse, i believe.
When i replaced mine, i had to bleed it 5 or 6 times, drive it a little bit, then bleed some more. Double check that you have the pushrod that connects to the pedal assembly at the correct distance so that full movement of the master cylinder piston can happen. what brand MC did you get?
DJNutshell
