COB's 1990 4Runner 2-Door
Battery tender was not getting good connection. Turns out that the truck’s ground terminal was cracked, so it would not tighten well over the post. Cut it off and replaced it.
Cleaned up the rear mudguards.
Before, they both looked like this:
After:
Round 2 on the paint.
1. Meguiars 105 + red foam pad
2. Meguiars 105 + yellow foam pad
3. Meguiar’s Gold Class wax
Driver fender complete and waxed.
Compared with the hood, which was previously polished, but not waxed.
With hood and cowl completed with wax.
Left side of the truck done.
Halfway across the rear tailgate
Tailgate completed.
Roof halfway
And done… trying to stop the fading… yes the turbo truck has faded :( but she will get a paint job someday.
Took off the wheels to get a good look at the brakes. Turns out she’s only got S12+8’s in the front. On the list - 93-95 V6 calipers, discs, pads, etc.
Rears are also small, 7/8” cylinders. Shoes seem to have some good miles left on them.
After a little brake clean.
Painted drum black.
Took these from one of my other rigs. These are FJ Trail Teams black 16” rims. Friend of mine recently got new tires, he gifted me his old set. Just had them mounted, Yokohama Geolandar M/T’s.
Installed clutch line in OEM position.
Some new parts.
Hood prop clip.
Rear main seal for 3.0 #90311-A0027
FIPG, oil strainer gasket, and two screws for the passenger reclining handle
New motor mounts
Rear main seal removed.
Front diff dropped, oil pan out.
More progress coming later, including completed oil pan and rear main.
Old motor mounts removed
New motor mount vs. old
Bare rear main
Rear main retainer
FIPG
FIPG on rear main retainer
Oil strainer gasket
Oil baffle w/ FIPG
Oil pan w/ FIPG
Oil pan installed
Rear main installed
Pilot bearing installed
3.4 5VZ-FE flywheel installed, new bolts, loctite, 65ftlb
5VZ-FE bell housing brackets for R150F
Driver
Passenger
AISIN CKT-040 clutch, new pressure plate bolts, 15ftlb
Nachi throwout bearing
Throwout installed, clutch fork greased
Truck on stands
Transmission on jack, ready for install
Transmission installed with crossmember
New view of shifter hole inside
Shifters installed
Offerup score - front mudguards
Mudguard installed, driver, w/ cap nut
Passenger
View, side
View, front
Side mirror swap, Old (top) and new (bottom)
Front view
Mirrors and flaps
Door panel, passenger, armrest swap
Panel later
Replacement door handle
Finalized door panel
Passenger seat, recline handle before
New screw for recline handle
Recline handle, after
New side window latches, not yet installed
DEPO tail lamps
Rear view
Filled with oil - 5W-30 full synthetic
Refused to start. Test of fuel pump through diagnostic connector came up with nothing. No fuel pressure, no noise from pump.
Tank pulled
Pump removal
Rusty pump
Removed pump, cleaned hanger
Used 5VZ pump, had in storage for years
New fuel pump harness from Walbro kit
New pump in hanger
Soldering wires
<iframe width="560" height="315" src="https://www.youtube.com/embed/TAwhvy78pRU?si=ml0eITKW1r4TKtVj" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen=""></iframe>
Moog 285 Greaseable U-Joints
Used driveshaft from 93 Pickup regular cab short bed, perfect length but with the wrong flanges
Installing new joints
Slip yoke with joint removed, correct flange
Shaft complete with 1990 flanges from original auto shaft
Joint 1
Joint 2
Shaft installed
Front diff installed
New AISIN slave cylinder
<iframe width="560" height="315" src="https://www.youtube.com/embed/dj-FNCjgvoM?si=21Jwv1ygYpYXQthV" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
IT’S ALIVE!
Quick wash
New 555 ball joints
Coated in POR 15 (some other parts for other projects shown as well)
New 555 outer tie rods, pitman arm, coated in POR 15
New power steering pump, coated in POR 15
New 555 outer tie rod ends, coated in POR 15
New 555 idler arm, coated in POR 15
Nice to have it semi-driving, still work left to be done before it’s completely ready to be a driver
Pressure wash suspension, engine bay, prepping for new ball joints and tie rod ends
Repaired side window latch. New aftermarket xtra-cab latch did not fit. I swapped the new plastic handle onto the original 2-door latch metal. It’s not an exact match, but at least now it works.
Daytime shots
Dashboard reinstalled
VSS harness, made from a VSS plug and sections of colored wire from an old 4Runner body harness
12V+ Pin 1 (black yellow)
Ground Pin 2 (pink blue)
Signal Pin 3 (gray blue)
Plugged into VSS
Run along old speedometer cable route
Pinned into OEM 1990 combination meter plugs
12V+ sourced from GAUGE fuse, connector A, pin #8
Speed sensor ground, connector B, pin #10
Speed meter signal (SIG-VAL), connector A, pin #1
Functional speedometer, TRIP, and ODO
Transfer case switch. Did not have other end to the plug, instead I removed the pins and swapped to another plug housing from a turn signal lamp.
Original female plug housing:
Replacement female plug housing sourced from turn signal:
Connected to opposing male plug housing with extra wire:
Transfer case switch connects to 3 total wires, located in automatic transmission blue 6-pin plug.
The following two wires must be connected to one transfer case switch wire (doesn’t matter which).
Pin #2, pink w/ blue stripe, automatic disconnecting differential detection switch
Pin #4, green w/ white stripe, transfer case detection switch
(Before soldering)
Second wire of transfer case switch connects to ground, which is the remaining white w/ black stripe wire cut previously from the blue plug.
Engaging 4HI from the transfer case shift lever will now result in automatic disconnecting differential system engaging the front differential to driveshaft, as well as 4WD light illuminating on combination meter/gauge cluster.
Reverse light switch connects to 2 total wires, located in automatic transmission large white plug (P1 connector). Doesn’t matter which side of the switch you connect them. It’ll work either way. Connect one of the following to each side of the reverse light switch:
Pin # 4 (black w/ orange stripe)
Pin # 8 (red w/ white stripe)
Connected:
I left the auto plugs hanging and zip tied the wires together to clean things up:
Reverse lights working with shifter in reverse position:
Further dash reassembly
Front driveshaft installed
Time to refresh steering and front suspension joints
Upper ball joint removed
Idler arm removed
Tie rods removed
Old units
New upper ball joint installed
New 555 idler installed
New tie rods installed
Lower ball joint comparison
New lower installed
Full shot
New shock stem bushings, energy suspension polyurethane
Pitman arm comparison
New pitman installed
Steering stop caps
Off to the Toyota dealer to get a new center link and alignment for free to due recall
Went back the next day and picked it up
Wheels aligned, steering wheel nice and straight
Got home and realized the front bumper valance had a big dent in it. Talked to the dealer and they’re going to review their cameras and see what happened. I had pics showing the truck at drop off so there’s no doubt that the dent wasn’t there before.
