COB's '89 Supra Turbo
Got a BIC performance downpipe, bellmouth
7M rebuild time!
Blown head gasket to say the least... #6 did have coolant in it.
Scraped deck. The block must have been surfaced before, there are no chamfers on the edges of the cylinders. The timing cover where the head gasket meets was leaking oil from being uneven.
Removed oil pan and oil pump, scraped oil pan gasket. Removed pistons and rods.
Crankshaft out
The crank pulley was hardly tight at all, the thing must have been wobbling a while to wear a groove into the end of the crank and destroy the keyway like this. The cost of repairing this crank was too much to justify.
Got another crank and pulley bolt, still looking for a pulley. Crank had some surface rust, cleaned it up and sent it to Bob McKray Performance to be polished.
Yes it is in the back seat of my MKIV :D I have another backseat in much better shape, or else I'd never do this shit.
Down to Precision Cylinder Head, a local machine shop, to get the head resurfaced, new guide seals, and valve job. Block to be surfaced flat with timing cover. Honing will reveal if it needs to be bored.
Head after sandblasting.
#6 after honing. This is the only cylinder with shadowing like this, so I've gone with sleeving the one cylinder rather than boring all six cylinders and having to buy oversized pistons.
Now waiting for parts to come back.
Crank back from polishing and it is much nicer than before.
Rod bearings, main bearings, thrust washers, standard size
Cometic 1.9 Metal Head Gasket and a teflon intake manifold isolator gasket
Now that's a head gasket!
Current state of the donor car :D
Block is back. Surfaced flat along with timing cover. Cylinder 6 has been sleeved. Looks excellent!
Sleeved #6
Resurfaced head, sandblasted, valve job, new OEM valve stem seals.
Parts... Rear main seal, timing belt, tensioner pulley, ARP studs... etc etc.
Took a little longer than expected, but I got my pistons and rings.
NPR rings 1mm oversize
Old and new.
Clevite bearings
Block ready for bearings and crank
Rings on, pistons in, rod caps torqued.
Rebuilt the AISIN oil pump + new o ring.
ARP head studs and cometic 1.9mm head gasket. Calculation puts the compression ratio just a hair under stock. Versus stock deck height/headgasket thickness, this 7M will be about .006" thicker overall with the cometic considering the current deck height (block has now been resurfaced twice in its lifetime)
Oil pump drive seal, cam seals, oil cooler seal, water pump gasket, valve cover gaskets, fuel J pipe gasket, etc.
Suspension Techniques sway bars
Half amber signals
You got my two dream cars 89 supra and 1st gen 4runner. I always have a chance to buy but never do. Some people want ferraris or lambos nah. Give me a clean turbo 89 supra and im happy. Maybe a 62 nova wagon will talk me out of both of them..
Anyways super clean car man, glad to see people still rebuild their engines properly. Dont see that much anymore always trying to take shortcuts or go cheap.
Definitely following this. Makes me want to get a move on with my mkIII. Maybe I'll throw up a build thread, too. :D
Looks great man, keep up the good work.
Incredible work. I see you posting on SF now. JamesR33 or something like that? Glad to see you on there and I noticed you picked up an MKIV from your neighbor! Congratulations brother, I'm about to check out that thread now.
Agreed, any twit with a big enough wallet can go buy a Ferrari (2014 is too old! I need the 2016 model to show off with!), it takes someone awesome to appreciate the older cars of the world. An older car with special care and attention shines best in my book.
dang. she's coming along! beautiful engine work.
what's left after the engine goes in? R154 work?
Yep, currently working on the intake manifold, gaskets/water lines, etc. Once it's done, R154, steering rack, suspension, install EVERYTHING.
My MKIII hasn't moved an inch in a long time, lol. Both of us need to get a move on. Hopefully yours actually works! Thanks fellow MKIII owner.
Yep I'm there. Finally getting the hang of things. Back in July '14, you were one of the first people to comment on this car, since I bought it from your area. I didn't venture too much onto SF until the MKIV happened. Now I see what all you guys liked so much about the newer Supras.
Timing cover...
oooh gotta love that fitment.
Oil pan installed, Permatex ultra grey
EGR cooler plate gasket
Brand new CPS cover/gasket
Head, cams out.
Rivets removed from Cometic HG...
Ladies and gentlemen, we have a longblock..
ARP studs torqued...
New Koyo tensioner, mitsuboshi timing belt, cleaned timing covers.
Time for intake manifold, accessories, gaskets, water lines, vacuum lines, etc...
One more for the... garage... I guess.
7M-GTE decal for timing cover, new
TOP - Turbo coolant line gaskets
BOTTOM - Turbo oil line gasket
Hoses
Water line gasket, plus the gasket for the water outlet housing
88 degree Celsius thermostat
Thermostat gasket
EGR gaskets
Intake plenum/manifold gasket
Exhaust manifold gasket
Exhaust manifold studs
Switched coolant lines, oil lines, actuator line, and installed new gaskets
Exhaust studs installed
Exhaust manifold and CT26 57 trim turbo. CPS has been installed with a new O-ring, cover, and cover gasket.
So far got up to the injectors, RC 550cc. All new grommets and O rings.
Heat shields also painted with VHT ceramic header paint
3000 pipe installed with silicone coupler and T bolt clamps
Wiring harness routed, a few repairs done to cracked wires
vacuum, pcv, etc...
NGK 5690 Iridium spark plugs
NGK spark plug wire set
Ignitor, bypass valve, etc...
7M-GTE timing cover decal
Ignitor cover, still a few loose ends, but mostly done
Up next: R154 rebuild
AISIN clutch master cylinder, new
AISIN clutch slave cylinder, new
And heres a little interior piece that needed attention. The A pillar trims are both scratched up and resemble the previous dash more than anything.
I've already bought a good condition passenger side, however, no luck with the driver. Decided to opt for a Lotek A pillar dual gauge pod. The dual is my choice due to the handle, I don't want to lose it.
Far from it, but surely nicer than most of the ones I see around town
JDM tail lights, dark red goodness
Tokico Illumina II for the eibach springs
And a cool reproduction power steering reservoir sticker.
Jhunt
