COB's '89 Supra Turbo
I agree about the wheels. I actually saw a white Honda with white wheels the other day and it reminded me of how awesome your Supra looks with the white package.
Haha I can see your guys point of view on this, although it is the size of the white rims I'm not fond of. I get an unspeakably killer deal on 18" tires (most of the tires we deal with at work are 18"), it is just too hard to resist going up in size. These bad boys are nice and wide, lightweight to boot. After all I really want to go staggered (can you say WIDE rear end? :moon:)
As for the white rims, AKA "sawblades", I'll keep em around. I think they'll find a good home in storage. I don't have the heart to sell the original wheels.
Front strut tower bar
ARP head studs for 7MGTE, brand new
Latest photos of my parts car... gradually taking it apart. Took the headlights out, using one of them for my 87 4Runner turbo which has a burnt low beam.
Untitled by cobblewagen, on Flickr
I have had a few mkiii supras and just a suggestion if you are gonna stick with the 7m look into a 5m oil pump and bigger pickup line. I think driftmotion has a kit for it. I have been out of that scene for a little while. my last one was a 2j swap and I was happy with it completely. made 426 to the wheels on the stock 440cc injectors.
never mind apparently they are upgrading the 7m pumps now, it's something to look into. I was never a fan of less than 8 psi of oil pressure at idle
Thanks for the tip. I will look into an upgraded oil pump, I would not want to experience any problems with the block in the future. Going to grind the crank for .010" larger rod bearings so the bottom end should be pretty solid in boost.
Top came back, wrong color. I understand this is panel painting but this was just an awful match. The people who destroyed the headliner were also responsible for mixing the paint, another mistake letting a body shop do the work.
This time around, my choice of paint shop is mixing up a better match. The paint should be ready by Monday and the top will get resprayed.
Here's the absolute JOKE of a headliner they installed... not having any of this... no.
Went on craigslist and found a Targa part out. Bought the headliner. I sent it out today to get rewrapped.
Replacement Targa top seals from Toyota
Sunvisors already rewrapped... I like them. The headliner is getting done with the same fabric.
No mirrors on these.
Folding mirrors should be done and back from paint next week
behold, the canyon:
Moving along
Dash out
Fixing up a little damage, glue and clamps.
Installed
Replaced the broken ignition cylinder/steering wheel lower cover.
From canyon to flatlands...
Going to repaint that cowl and install new wipers sooner or later
Headliner rewrapped
Got a set of door panels. The passenger one is in excellent shape compared to mine. The driver's one has a big damage spot, but still better than mine regardless. Mine have armrest tears, these do not.
And last I picked up some paint, all matched to the car.
1/2 pint for the top and mirrors
touch up bottle
8oz spray can for future projects
The driver door panel vinyl in my car isn't pretty, still looking for just the right panel to replace it. In the meantime, I took the carpeted middle and lower sections which are less faded.
Old (top)
Old (bottom)
installed on the panel, along with the lower portion
Swapped in the speakers from my donor car while I was at it.
Also replaced the malfunctioning lock switch with that from my donor car
Passenger side I replaced the entire panel and swapped speakers.
Old panel
new panel
One more for the road... that dash :D
Got my targa top back... again
Installed headliner
It's starting to look like a roof again, just gotta install the side trim and seals.
Last, a friend bought a new 4Runner TRD Pro, I cut this from the plate frame. I like it, looks like an old school Toyota logo.
7MGTE coil pack cover without cracks :)
1UZ MAF
Shifter boot
R154 inspection cover
Competition clutches aluminum flywheel, south bend clutch
RC 550cc fuel injectors
Also installed the hood again to try out some hood struts
Parts car
A couple videos I put together.
<iframe src="//www.youtube.com/embed/P3T1E7QfFuM" allowfullscreen="" frameborder="0" height="480" width="853"></iframe>
<iframe width="853" height="480" src="//www.youtube.com/embed/TjDDabHHxv0" frameborder="0" allowfullscreen></iframe>
Trying out a new interior photography method... inside the car with the cover on. When the interior's all ready, I'll do a nice shot showing the seats and center console, etc.
Got her up on jack stands.
[MENTION=75445]4Running Daily[/MENTION] gave a helping hand.
Bell housing bolts:
Flexplate showing, trans out. View through shifter hole.
Ugly mother f*cker
Motor coming out, outside to set up the hoist.
7M-GTE out of the car.
Bro lean
Thanks for the help, Connor
