*** Coilovers spring question for TRD Pro coilover***
10ac
I have ordered the TRD Pro suspension kit that has the bilstein style 6112 and bilstein rear 5160. So the TRD front coilover has only 2 clips to adjust the spring perch. Reason for I have read is they set one on the top setting to help the Toyota lean. So what I need is more lift. I want to achieve 3” and if it’s a smidge more then I will be ok w that. But at least 3”. From what I’m reading is the Trd red coils are 600lb rate and 14” long. Could I just buy a 2.5” front coil spring set at 600lb rate but taller to get more lift? What can I do to get more lift? I wanna say the bilstein 6112 that’s not TRDhas more grooves for the clip to adjust spring perch higher. But just asking y’all. If I can just buy a set of different coils and get 2.5” then I’ll add a top plate spacer for the additional 1/2 I need.
Any info and help appreciated
From what I’ve seen on googling the Trd style 6112 and the regular 6112 is that there are more clip settings on the perch to allow for 2.5” of lift. Since I don’t have as many clip settings, I will need a thicker spacer style lower spring perch such as the toytec but a bit thicker to make it seem as I have the perch higher like the regular version of the 6112. Hmmm? Guessing that’s my best bet
