The quote above is accurate. CDOT started using salt (a sprayed solution before storms on highways) last winter. Pisses me off. Rust will get worse going forward, we need to start protecting our trucks.
You guys are going to have to start Fluid Filming or something. Utah too from what I'm reading.
Colorado DOT...
https://www.codot.gov/travel/winter-driving/faqs.html
What kinds of road treatments and techniques does CDOT use?
As in years past, CDOT will utilize a variety of products and techniques for the most effective treatment of snow, slush, ice and black ice on Colorado 's state roadways this winter. Products you will see used in differing combinations include sand, a sand/salt mixture, and various liquid anti-icers and de-icers. The type of storm and temperatures will dictate the products used.
What are liquid anti-icers and de-icers, and how do they work?
Anti-icers, or preventive winter road treatments, are liquid forms of salt compounds used to prevent the formation or development of bonded snow and ice for easy removal, and are used at the onset of a winter weather storm. They work by lowering the freezing point of water.
De-icers, or reactive winter road treatments, are liquid forms of salt compounds used to break the bond of already existing snow and ice. They dissolve downward and penetrate until they reach the pavement. De-icers melt the ice and snow it may be easily removed by mechanical means such as plows. They are not necessarily intended to clear every bit of ice and snow on the road, though the goal is to keep roads wet.
Both anti-icers and de-icers are winter road treatments that work as freezing-point depressants and are the most desirable and environmentally friendly way to treat winter weather roads.
How does CDOT determine when to use anti-icing and de-icing techniques?
A variety of factors are taken into account when deciding upon a course of action to treat winter roadways. Product application combinations are chosen after maintenance workers evaluate many factors including air and pavement temperature, humidity levels, dew point temperatures, exposure to solar radiation, type and rate of precipitation, weather forecast, weather radar data, and satellite data. CDOT monitors road conditions using infrared sensors, thermal mapping, and Road Weather Information Systems (RWIS).
Operational treatments are continuously evaluated by CDOT before, during and after a winter weather storm. Road treatments and applications are modified through all phases of a storm based on careful analysis of intensity, duration and type of precipitation.
