Coming Soon - Direct Plug & Play Rigid Industries Fog Light Kit 2014+ 4Runner
Don't order the harness. They're on eternal backorder. I've been waiting for mine since January,and finally was able to install mine with help from [MENTION=116156]TheWraith[/MENTION]. Rig up an adapter, direct wire them, or go with another brand.
are there any installation write-ups with pics?
On vs Off
Here is a view from inside on my drive home tonight
Can you please post a pic of the road with and without the lights on?
Thank you in advance
After a 5 month delay the PNG harness is now back and stock and available for this kit!
We have qty 27 left.
We also have 3rd/4th gen in stock :thumb3:
Call 702.979.1577 to order yours!
Also looking forward to Amber colored if thats going to happen
The only pre-packaged kit we have put together is the one with the DOT/SAE Dually. If you want a different light, no problem! You just have to add the following individually.
Amber Dually Flood - Rigid Dually - 20212
or
Amber Dually Spot - Rigid Dually - 20222
or
Amber Dually D2 Driving - Rigid Dually D2 - 50232
PNG Conversion Harness - PNG Harness by MRT Motorsports
Rigid Fog Bracket (Does not fit limited models) - Toyota 4Runner Fog Light Kit 46540
Add the items youd like to the cart, then enter the code LIGHTME to get our forum discount. If we can be of any help, call 702.979.1577. Thanks!
Thanks you! According to [MENTION=118252]Chas of MRT[/MENTION], they are an updated version featuring a more flexible outer covering, different wire and better debris intrusion protection.
Ordered less than an hour ago and already have a shipping notification and tracking number.
Nice to get great customer service! Much appreciated!
Just received mine today. Super easy install with it completed in well under an hour. Great quality, bright and they look great. I will post pics later.
D2 Driving Ambers installed yesterday, everything went smoothly, my pics suck as usual but i'll leave a few notes about the install:
- removed 2 screws from the underside of the fender liner, peeled it back and hooked it around the tie rod to keep it out of the way
- as [MENTION=105498]sovat4r[/MENTION] mentioned earlier, the passenger side has a plastic cover surrounding the fog light that needs to come off as the slots clips into are used for the tab on the bracket and covered by the plate for the mounting screws. it popped off with minimal effort
- the rigid wiring, pnp harness, and factory wiring combined make for a long chain of wiring. to keep this somewhat elevated and from jostling around too much i looped it over a metal brace along the outer side of the bumper cover (shown in pic)
- used some thick rubber gasket type stuff found at surplus store to fill in the angled gap left in front of the light (shown in pic)
oh and how could i forget, [MENTION=120150]TotalAutomotiveLV[/MENTION] : preesh, y'all are a great vendor!
Can someone post a photo(s) of the wiring with the plug and play adapter, its connection to the factory fog wiring and how you all managed the wiring so it is clean and organized? I installed my D2 driving lights in the factory fog housing using Rigids bracket but haven't wired them up, because I want to be sure it's done perfectly. Thanks, George
IMG_4655%20copy_zpspbda5eew.jpg~original
Check this out!
http://www.toyota-4runner.org/5th-gen-t4rs/220424-rigid-industries-dot-dually-fogs-installed-2.html
