Compatible Oil Filters both V8 & V6
message
Member
Thought I would do some research on my own as much of the information on running alternate oil filters for V6 and/or V8 4runners is more or less biased. I basically want to run something larger as I don't believe the standard issue filter (M1-102) to be adequate.
So here's some of my findings I thought I would share, take em for what they are worth and don't come back to me if your engine blows up... :cheers:
Via Mobil1 Parts Catalog - Mobil Online Parts Catalog
The standard oil filter for V6/V8 is of course the M1-102.
Outside Diameter: 76mm
Height: 86mm
Inside Diameter & Thread: 3/4"-16
PSI Relief: YES
Anti-Drain: YES
From there I looked at every filter Mobil1 makes via the Part Search and found the following filters that "should" also be compatible.
M1-205 and M1-209.
Both of which have the same dimensions and feature set.
O.D.: 76mm
H: 86mm
I.D.-Thread: 3/4"-16
PSI Relief: YES
Anti-Drain: YES
NOTE: I left out filters that were slightly smaller/larger by even 1mm in outside diameter and/or did not have PSI relief/Anti-Drain features.
Mobil also lists some M1-102 cross compatible filters (not the M1-205 or M1-209) but alternate manufacturers... One of which I thought was rather interesting so if you want some bling you could run this :)
PH7022 - Harley Davidson(87-04) & Buell(87-08) Chrome Oil Filter
O.D.: 80mm
H: 87mm
I then did a cross reference of Mobil1 filters with WIX filters - WIX filters, WIX oil filters, WIX air filters, WIX fuel filters, WIX Heavy Duty Oil Filters : Filter Look-Up.
WIX is nice enough to offer several more specs from which I see the M1-209 is the only filter interchangeable with the M1-102 in my mind.
I should also mention I did see another thread where others on here are running the M1-209 with success. I now plan on doing the same as clearance does not appear to be an issue with the M1-209 on a V8.
M1-102 --> 51348
O.D.: 76mm
H: 86mm
PSI Relief: YES
Anti-Drain: YES
Max Flow GPM: 7-9
By-Pass PSI: 8-11
Burst PSI: 275
M1-205 --> 51342
O.D.: 76mm
H: 86mm
PSI Relief: YES
Anti-Drain: YES
Max Flow GPM: 7-9
By-Pass PSI: 16
Burst PSI: 350
M1-209 --> 51516
O.D.: 76mm
H: 86mm
PSI Relief: YES
Anti-Drain: YES
Max Flow GPM: 7-9
By-Pass PSI: 8-11
Burst PSI: 275
-Larger Size-
AC/Delco: PFL400A
Amsoil: EAO34
Baldwin: B243
K&N: HP-2009
Mobil 1 Extended Performance: M-209
Purolator Classic/Prenium Plus: L20195
Purolator Pure1: PL20195
NAPA Gold: 1516
WIX: 51516
Motorcraft: FL400S
The OEM filter for 3rd gens is far superior to anything aftermarket.
Aftermarket companies make money by selling a lessor product after convincing buyers theirs is superior.
I have seen a Toyotal oil filter cut open next to a FRAM. There is no comparison.
Go OEM and unless you have actually seen the aftermarket cut open, don't believe the internet hype.
:P
I definitely agree that OEM filters are legit don't get me wrong there.
I was primarily looking for what my options are for running a larger filter than stock while still staying within specs for bypass pressure and diameter.
Well based on your post you probably know more about this then I do but like I said above, I once saw a display that had both the OEM filter and a fram cut open.
I literally :wow2: :wow2: :wow2:
Because the difference was so impressive in favor of the OEM filter.
:keyboard:
I have the M1-102 in right now, but recently bought a ten pack of Toyota 90915-YZZD3 filters off ebay for a good price so switching over to those... only hear good things about the denso filters made for Toyota. I have nothing against the Mobil 1 filters, they're just more expensive.
