Compiled: Satoshi Build, Help & Picture Thread
Question for all those Satoshi owners with an emblem. How did you fasten the emblem to your grill? I got the 80s FJ emblem for mine and I am trying to determine a way to mount it without cutting the grill behind to make room for the nubs that are on the back of the emblem.
I want it to lay nicely on the grill but be non destructive to my mesh in case I want to remove it later down the line.
Any ideas?
I've been lucky that I've been able to center all the emblems well and have the nubs protrude through the mesh diamond.
I stack some washers on the back to make it flush with the nubs then use #8x5/8" SS sheet metal screw in the middle and a nut or small washer on the other nubs.
edit -
Any ideas?
3M Molding Tape
Amazon.com: 3M 03614 Scotch-Mount 1/2" x 15' Molding Tape: Automotive
[MENTION=55855]zopperman[/MENTION] mentioned using this. I was skeptical at first and thought the emblem might fall off on the freeway, but this stuff has a VERY strong bond between my grill and emblem. I tried pulling at the corner of emblem the other day and it was so strong, it felt like I'd probably pull off the mesh before I pull off the emblem
3M Molding Tape
Yep, I was gonna use bolts, but it was too annoying to get them all aligned, so I taped it. Stuff is really strong. It's different for me since I have separate letters too, don't forget
important question: paint the Grill flat black or semi gloss?
Definitely flat. I would have gone with flat black myself but chose to have my mesh powder coated by the company I purchased it from. With your white runner, I think flat would look the best.
this needs to be stickied! if "lift suggestions" threads is the most common unnecessary thread created by noobs, "satoshi grill help" threads are the second most common unecessary thread created by noobs!
I also noticed that Bay Area Metal Fab now customs and sells the raptor style words for anyone that doesn't want to do it themselves
Raptor Letters
it can be purchased saying either "toyota" or "tacoma", the latter of which probably wouldn't make much sense on our rigs...
this seems to be for the letters only, mesh is not included
another possible emblem that can be used is the 4runner emblem from the rear hatch of the 5th gen
I believe this is the one used by [MENTION=55855]zopperman[/MENTION]
I used that one, correct. I modified the R's because they looked silly. I may sticky this. I'll think about it for now :thumb3:
More pics...
I still need to paint the radiator, horns and other visible items behind the grille to give it a cleaner look.
IMG_20140101_122015170_HDR-1.jpg~original
IMG_20140101_121838886_HDR.jpg~original
IMG_20140101_121926041-copy.jpg~original
Here is how I attached the mesh to the back of my grille. I chose not to do a flush style mesh so the mesh just sits flat against the back side of the grille. To get the cleanest look possible, I didn't want any screws, bolts, etc visible. On the top, I epoxied threaded rod in 5 spots against the inside lip of the grille opening. I made sure to position my mesh first then marked where the rods would fit into a mesh hole.
IMG_20140101_113007853-1.jpg~original
On the bottom, I decided to drill holes in the black frame support of the grille. I used 2 zip ties to create an anchor point for each hole. One zip tie is zipped closed below the frame and the top zip tie goes down through the hole, through the lower zip tie and back up through the hole and zipped closed. This creates loops to zip tie the mesh to. Overall, it is very sturdy and best of all, you cant see any of the anchors, including the threaded rod from the front of the grille.
IMG_20140101_113056346-1.jpg~original
IMG_20140101_112950549-1.jpg~original
I am still deciding on if I want to include an emblem or not. I purchased the FJ "TOYOTA" emblem but am not sure I like the white lettering. Black is more my style but I am afraid if I paint it, it will just look like a blob and not lettering due to the black support each letter is connected to. I have seen the sweet emblem mod one of the taco owners did but honestly, that is just too much work for me at this point. Any suggestions on how to paint my emblem?
I have had no experience with fiberglass, bondo, auto paint, or any of the items required for this style satoshi. It was very frustrating at times but overall, a great learning experience. If you want this look for your 4runner and have the motivation, go for it. Some words of wisdom so you can learn from my mistakes:
-When doing the fiberglass, make sure it is flush with the back side of the inside opening. I used tape on the inside of the opening (visible side) and the fiberglass clung to that tape causing it to be more flush with the visible side than the back side (confusing, I know). The reason this was an issue is when filling the holes, you want the fiberglass to be a backing to the bondo. If your fiberglass dips inside, there will not be enough of a gap for the bondo to fill and when sanding the bondo, the fiberglass begins to come through and get very thin. My remedy, other than cutting the fiberglass out and starting fresh, was to put bondo on the other side of the fiberglass as well to not only support it, but in a couple of spots where I sanded through the fiberglass, the bondo filled the hole from the other side.
-If you are painting to color match, be patient! Should be common sense I know, but its a huge pain if you aren't. I painted my grille the first time on a sunny day and after letting the pain cure for a few hours I got ancy and decided to flip the grille over to attach my mesh. The paint wasn't completely cured and after flipping my grille back over, I had a huge dent in the paint in one spot and another spot the paint was bunched up revealing the primer underneath. As result, I had to re-sand my entire grille, getting all the paint off and repaint. Quite tedious and expensive (considering a can of the color match and the 2K clear is around $60-$70 including shipping).
Other than that, take your time and ask questions if you have any!
Still trying to figure out what I want to do with my emblem. I have sort of a blacked out theme on my 4runner with my matte black wheels, black mesh in the grille, etc. so I wanted something to match. Unfortunately, I used all my color match paint when painting my grille and im not certain I want to drop some more cash for another can so I went with a dark silver outline for now. Still needs to be touched up but I am not thinking that I like it very much...
Took about an hour to tape off after my base flat black color.
IMG_20140108_205852751.jpg~original
Prior to touchup:
IMG_20140108_232505543.jpg~original
Finished my Satoshi last night and put it in today. Have more pics I will upload from my computer later.
Great job looks good:thumb: Thanks for the write up i'm going to be doing this soon and i want to do the same style you have and also don't have any experience with fiberglass and bondo. Where did you get your mesh from for the grill?
I got mine from custom car grills. I suggest that if you are going to get yours from them and are not sure what style you want, order the large sampler pack. It's $5 but you get a coupon code for $5 off an order over $20. Links to both the site, and sample pack are in the OP under the materials section.
Good luck with your grille! I have had mine on for just a week now and I love it! Just need to get my emblem situation figured out.
Feel free to ask questions here if you get caught up. I know there are a couple members who have done their own grilles that watch this thread.
Did a test fit to see how I like the paint job on the emblem (crappy cell phone pic). I like it but am too OCD to have the outline a different color than my 4runner. I ordered some touchup paint and will re-do the emblem with with a galactic grey mica outline.
Ok great thanks appreciate it.I can't wait to do this mod I think it completely transforms the whole front end of the the 4runner!
Emblem looks awesome by the way!
