Confed 1" rear spacer w/Bilstein @ 1.75
Blue15
Member
Just looking for any issue's with, are you happy with, and has it provided the rake desired with front bilsteins set @ 1.75.
Doing my measurement it would seam the Daystar 1.5 would give more of the factory 2" rake. The 1" Cornfed a more subtle rake but still enough for rear passenger, or light gear load.
Are we limited to only a few rear coil spacer manufactures, Cornfed, OME and Daystar?
The 10mm is considered a "trim packer". They are to adjust for the occasional side to side lean that occurs from some lifts.
I have the 5100's set at .85 and I had corn fed make me a 3/4" spacer for the rear. I think I would have been most happy with a .5" spacer in the rear. But I'm not going to change it now. Contact corned directly, they'll make whatever you want and it's cheaper than going through burtman or other retailers
Not increasing the rubber size, and just don't need all that space.
[MENTION=81573]Stifler[/MENTION] ran 2.5/1.5 on 265s. Lookd great and when he went up in tire size he didnt have to redo the lift
4r_zps6ddc99f6.jpg~original
Just left Toyota, labor $660 to install four bilstein, rear spacers and re-align. For that kind of money may what to think about all the way up. I supply the parts, they were $490 on the four shocks and $80 on the daystar. I suppose i can get for less on line.
What are the biggest size tires possible without rubbing or trimming with the Bilstein 5100s set to 1.75” in the front and 1” rear cornfed spacer?
Lift with IFS does not change tire fitment or rub. So stock size is the biggest with no rubbing or trimming. With a fender liner adjustment, front bumper lip trim, and removing mud flaps you could fit 285/70/17 or any of the sizes between that at oem size. With narrower tires like 255/75/17 you can probably keep the mud flaps but will still need the bumper liner/trim on the front side of the fender wells.
How much would trimming to fit 285/70/17 cost? I definitely at least want to go that big but don’t know much about trimming.
No cost. All you need is a box cutter type knife and a screw driver. Google the 4runner fender liner mod. And you may need to remove the mud flaps. That's all.
