Consolidated 5th Gen Skid Plate Info Thread
I bought the regular one since I was advised I’ll probably only need the wide one if I plan to rock crawl. I think it’s very well made, it’s solid and heavy for sure. I can comment more once I install it next since I’m getting close to changing the oil. Overall, I’ve had great experience with LFD.
Where are the interior supports of this front skid plate like those RCI and Bud Built have?
Where is the bulge to accommodate the front differential? If the whole skid plate lay lower than competitors' to accomplish that....
And where are the gussets for the oil change door?
One good front hit, one good underneath hit and this skid plate is deformed and pushing against parts.
On a related note, does anyone have pictures of the inside of the new CBI front skid plate? It always amazes me when sellers have insufficient pictures; CBI and C4Fab come to mind.
I spent a lot of time looking for better photos / reviews of the CBI skids. I even contacted CBI using their site ... came up empty except for this, which is more Jason talking about his thinking than the product. CBI did not reply.
I'm not sure if they don't sell many, or what, but hard products to find information on ...
On the outside, it looks like a good plate but I really do not understand sellers. I mean, ok, most folks don't buy aftermarket stuff to really use it, but I would think skid plates are an exception.... The gas tank skid they show looks beefy as the Shrock and the C4 offerings but it lacks cutoffs for water and mud egress. Not sure how one cleans it.
On a different note, I pulled my front three skid plates, which are my RCI plates. Of course, I have been looking at them often from the outside, but I thought I would clean them, chase the treads in the holes, and take care of all the places where the powdercoat has been stripped. I am not sure I see the point of powdercoating them, but I did not know they could be had in bare steel when I got them as the site does not show such an option.
One of the tubular supports of the front skid is now at a mild angle and not straight. I guess that happened when I hit a rock at speed and bent the front where the oil change door is. The bulge under the front differential is not only stripped of powdercoat but also rusted on the outside. I have to check if the inside touches the differential. I have lost the tread above the hole where the other tubular support bolts in. I guess that is the cause of an annoying noise I have been hearing offroad (or not). Will see what I do there.
But, no, no damage to the vehicle. The RCI front skid has taken the beating and I think it can take a lot more.
For the transmission skid, I have the optional support brackets on the inside and I think they should come standard. It is nicely scraped on the outside, but is in perfect shape.
I am especially impressed with the transfer case skid because this is the one that works all the time. The brakeover angle, especially with the skid, can be insufficient even on moderate trails ( I am not using the word loosely as most do; a moderate 4x4 trail is typically a straightforward trail for a 4Runner; a moderate rock crawling trail for highly modded rigs is another story). But in between the shape of the skid and the additional crossmember to which it bolts, it is in great shape. I do use the hose clamp mod and I do also use a zip tie to make sure I do not lose it if it falls off.
Back to the front plate, I am not in principle thrilled that it is narrower than the stock skid but haven't had an issue. Still that is a bit of a concern, but not a great one.
I also rust treated the underside of the A-arms, which have a bit of rock rash, the scratches on the underside of the Shrock sliders, and I had already repainted twice the Total Chaos skid protecting the pax side rear LCA bracket which takes the award for most smacked skid so far. The gas tank Shrock skid has some very minor scratches.
I will need a rear diff skid if I don't want to have drain plug issues and if I want to preserve its appearance should I ever want to sell the rig (doubt a dealer would care but an informed private buyer might).
Is "Hefty" that was mentioned Hefty Fabworks? They make 5th Gen skids. It was noted that "Hefty" did not.
Store - Hefty Fabworks
I did not have Hefty Fabworks in the first post which I have updated with their links. However it looks to be a super-new product offering with no stock on the shelf, pre-ordering available and a 6 to 8 week wait. They seem to only be offered in aluminum.
I really appreciate the pointer to their offering!
great thread..thanks for consolidating all of this..been leaning towards the RCI..don't really need a skid plate but I like the idea of having easy access to the oil filter.
Hefty and MORE make it two more options that did not exist as recently as this time last year.
But both are aluminum only and the Hefty's price is a good match for the shop's name. I suppose the other one will be no different.
Why no 3/16 steel? Using discounts where available, I switched to armor for all essential spots (front, mid, transfer, gas tank, LCA brackets, and the rear Rockmen LCAs themselves) at the price of a partial aluminum non-RCI package. Ok.
I trust that a well-gusseted aluminum will take bad hits but that's 50% of the reason to upgrade from stock, the other one is dragging and aluminum won't do as well there.
I guess the intended audience is that of heavily built rigs where every next pound of permanent weight is an issue with the V6. Not that an overlanding rig on a 2" lift and 33s really needs any aftermarket skids. And if it does with that amount of clearance, it will want the steel version anyway.
All the while, my GX470 friend cannot find anything off the shelf for his rig. With a V8 standard, the GX can take steel all day long yet nobody seems to offer even a front 3/16 steel skid plate for it.
Is steel passe' ? Not cool?
My 2c.
See this thread for the announcement from BattleBorn for their M.O.R.E. skids offering
New Product Sneak Peek! M.O.R.E Skid Plates for 5th Gen 4Runner - Only @ Battle Born!
Coming soon from M.O.R.E. & Battle Born Offroad!
5th Gen Toyota 4Runner Aluminum Skid Plate System
Battle Born Offroad has teamed up with Mountain Offroad Enterprises to develop skid plates for Toyota 4Runner offroad enthusiasts from the weekend warrior to the most hardcore! Our 3 part modular main skid plate system offers maximum coverage to protect all vital components from the front all the way back to your transfer case. Our fuel tank, differential and lower control arm skids provide even more protection for the most adventurous. Made out of aircraft grade 1/4” aluminum, all skids are gusset reinforced on the inside to protect against hard bashes and hangups on rocks. A dedicated jack point was incorporated into the the front skid plate enabling you to lift the full weight of your vehicle on a single point without compromising the skid plate. All metal and materials are 100% sourced from the USA and all skid components are 100% made in the USA!! Upon release, these will be offered raw aluminum or powder coated a color of your choice. Pricing is TBD. These plate will be ready to ship to the public within 90 days, exclusively from Battle Born Offroad! These are currently being tested on a variety of trim levels with and without KDSS to ensure the perfect fitment on all models before being released to the public. If you have any questions feel free to shoot us a message!
Product List:
Oil Pan Front Skid Plate
Transmission Skid Plate
Transfercase Skid Plate
Lower Control Arm Skid Plate
Differential Skid Plate
Fuel Tank Skid Plate
Battle Born Offroad Is The Only Source for M.O.R.E. Toyota Products
About M.O.R.E
M.O.R.E. began in Chris Overacker’s home garage in 1978. M.O.R.E. was the first to bring the Jeeping community the Shackle Reversal System for Jeep® CJ /YJ models. Mountain Off-Road Enterprises (M.O.R.E.) specializes in providing the highest quality products for offroad vehicles that we design and manufacture in-house using premium materials. We use our own personal vehicles for daily driving, exploring, rock-crawling, camping, fishing, hunting, gettin' stuck, and racing around with our buddies! Take a look at the extended selection of top-quality, wheeling hardware made right here in the U.S.A.!
Battle Born Offroad of Las Vegas, NV. We are your source for 4Runner offroad parts and accessories. Contact us for all your upgrade needs!
Victory 4x4 5th Gen Skids
Here are the Victory 4x4 prototypes of the Engine, Tcase, and Transmission skids. We don't yet have the gas tank skid prototyped but it will mount similarly to our Tacoma gas tank skid. (to the frame, not using the stock gas tank straps). They will be offered in 3/16" steel or 1/4" aluminum (mounting brackets will still be steel).
Follow this thread for prototypes, new products, and info about Victory 4x4!
Victory 4x4 New Product Prototyping (Armor & Accessories)
Learn more at:
Victory 4x4 - There & Back
That's pretty much what I already posted an hour before you. How about some good pictures of what we cannot see on the skids? Especially any reinforcements of the front skid and how it fastens to the 4Runner.
Thanks for the post, I saw that after I posted. I just posted a couple more pictures of the underside of the skids in that thread. We will have more photos and a full install video in the near future.
Its not on the website yet but i have seen it. This was the first prototype. It has been modified slightly since and is going into production.
Thanks for the updates! Since it cannot be ordered yet we can wait a little bit more and update the first post after they update their website.
Philthyphilthy
