Hmm, I've never considered an H8 bulb as a replacement for my h16 fogs. I agree that that stock fogs are incredibly weak... especially now that I've replaced my low beams with the xtreme HID kit. The fogs just get washed out and don't do much.
I haven't been a fan of a lot of the LED options either. The light output is horrible unless you change the lens/housing too.
Anyway, I might run by Autozone on my way home and pick up a set to see if they're any better. Worst case, if they don't fit, I could just return them.
I'll post some pictures if I happen to get to it tonight.
That would be awesome man!! Here are the photos of both I found:
H16 (19W, 500 Lumens):
H8 (35W, 804 Lumens):
Also, I'm thinking beam pattern, etc. should be fine since filament placement seems to be pretty much identical. Here's something I put together after scaling both images to be the same:
