do you have a link to the DRL disable mod?
New 4Runner owner here, just 2 days in. So I drove last night in very dark conditions, not pitch black like we get on county roads here but still pretty bad visibility. And I'm appalled at the performance of the low beam on this truck. On 70mph winding highway with reflective lane separators I could barely do 60mph because the low beam is so poor. I'm not sure how it passed safety test. I have good vision and drove that road many times. My old 2003 Pilot with washed out and scratched lenses is allot better than my 5th gen 4Runner in terms of illuminating the road. How do you take this thing on forest roads where it's pitch black? All those off-road capabilities means crap if I can't see where I'm going. These are the worse stock headlights I've encountered so far in my 30 years of driving.
Now that my ranting is over, I'm going to install the H9's in low beam and see if it will be enough. Not willing to do HID's because blinding oncoming traffic is a no go and realibiliy is a concern.
Headlight Revolution just did a great test comparing several different LED and HID bulbs in the stock projector housing. I’ll be ordering these GTR’s soon. Check it out:
YouTube
Let us know if you get these. Because casting is a weakness of LED's, I wonder how the GTR2's performs at the distance in a Toyota projector.
"LED fails (in nearly all cases) at reproducing the same light source characteristics that they replace. In some lamps, they come close but its not perfect. You can't just look at a beam on a wall and say "yeah the LED looks like it matches the same pattern". Or put up a cheap lux meter on the beam and find the brightest point of intensity and then say "yeah this LED is 497% brighter than halogen so it definitely is better". No - that's not how it works. A headlamp is designed and engineered to produce a specific unique beam pattern that distributes light at specific angles on the road for safe visibility while being in compliance to the federal lighting standards. Change the light source type, size, shape, luminous flux and it throws all the optical engineering out the window and ultimately the beam pattern. You could end up having only a 20% increase at the 75 meter angle test point even if the LED measured at 497% more lux. How? Because of the focus. It shifted the intensity to an angle that doesn't help you see farther."
Author Evo77 @ hidplanet.com
YouTube
does anyone have experience with GTR LEDs? I'm also looking to replace my high beams with XenonDepot Xtreme Pro LED because they have "DRL" functionality.
any feedback on these 2 products is great appreciated!
I have the extreme LED high beams (w/DRL drivers) and Morimoto 2stroke 2.0 for the low beams.
I've switched back to halogen. H9 for the low beams and 9011 HIR for the high beams.
The problem isn't that LED lights aren't bright-they're SUPER bright. The problem is that they're trying to replicate a halogen filament size and placement, and there's just no way to get the emitters and blades thin enough to do that. So the lights are bright, but only your near-field view improves because the focal point of the light source is off. You THINK it's an improvement, but you need to pay attention to realize you're only seeing things 50 feet in front of your truck, and nothing beyond that.
Even the low beam h9 replacement is not perfect because the focal point is shifted one degree to the right at 25 feet vs the standard bulb. As distance increases so will the spread as it increases exponentially. I haven't done the math but at 200 feet it could be as much as 25 degrees of to the right. Should really help when taking that left turn on a highway at night ��
I didn’t realize how many LED haters there were out there! I appreciate all the points raised here, but I think we can all agree that the stock setup sucks. So then, what’s the best way to improve visibility?
Ok, so I'm kind of dumb when it comes to lighting. What can I get that will improve the low beam visibility? What brands/models, etc? Are all of these just drop in upgrades?
Philips H9 halogen bulb. Get two.
